Recommend Fall Arrest Harness/System? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-26-2012, 11:58 PM   #1
Maryland
This spring/summer, we'll be doing some steep roof work and also re-siding a 2.5 story house from pump jacks. We're looking for a personal fall arrest system that will be sufficient for both purposes. So far, we've determined that we'd like to use a shock absorbing lanyard, but we're still up in the air about the harness and anchor point(s). Also, it seems like it would make life easier if we had a lifeline and rope grab. (Could work further from the anchor point than just the lanyard length) We like the look/description of the systems from Miller, but we're interested in hearing opinions from those of you who have experience with different systems.
What manufacturers/brands would you recommend? Any recommendations on harnesses? Type of anchor points for roof/siding? 25' or 50' lifeline? (Max roof height is around 36') What do you use personally?
Pittsville is offline   Reply With Quote
Old 03-27-2012, 07:22 AM   #2
EIT/DIY'er
Have always used Miller.
For lifelines, all work I've done with them has been engineered installations compete with stamped calcs and drawings, however my work is mainly industrial so I'm not familiar with standard practices in the residential arena.
Each anchor point must be able to withstand a 5000lbs loading...per person attached to the anchor point. Might want to take a look at Miller's website to find products suitable for your application (maybe their temporary roof anchors) and be sure to follow the instructions perfectly.
Lattimer is offline   Reply With Quote
Old 04-02-2012, 12:30 PM   #3
I sell Miller fall protection and would be happy to assist you in finding just the right equipment.
mike_genovese is offline   Reply With Quote
Old 04-02-2012, 02:06 PM   #4
Rewards Points: 252
I would suggest taking a course, just so you know what you are getting yourself into. They are usually half a day, a couple hundred bucks, and will give you info on what to look for in a harness, how to set them up, and what to use for lanyards.
shazapple is offline   Reply With Quote
Old 04-02-2012, 02:08 PM   #5
I can also set you up with the training if you're interested in that route as well.
Lawn weed killing in the fall? AGWhitehouse Landscaping & Lawn Care 11 08-12-2011 02:19 PM
fall arrest system for DIY? bergerdude Roofing/Siding 2 07-02-2011 08:55 PM
Need help with fall protection equipment and technique. RickDel Roofing/Siding 5 06-10-2011 06:36 PM
Wooded lot - Fall overseeding in NC HomeinNC Landscaping & Lawn Care 10 10-04-2009 11:19 AM
new home, new lawn, fall care ? mahjohn Landscaping & Lawn Care 3 09-06-2008 03:38 PM
