Ready For Re-Roofing - Pase 1 - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-18-2012, 07:49 PM   #1
Ready for Re-Roofing - Pase 1
I am preparing to re-roof my barn, hoping to complete it before winter. I was on the roof earlier today and started to clean it enough to use that spray-rubber sealer to seal leaks until I can re-roof. But after sweeping the known bad areas, I started researching synthetic underpayment. (Thank God for iPhones with Internet access.).
Are the synthetics really good for up to 6 months by themselves? If so, I may tear off the old shingles and tar paper to replace the bad wood and install new synthetic paper while deciding to use shingle or steel roofing. Either way, it will be DIY. How much overlap do you need between the sheets?
The roof line is not particularly steep, but joins a more shallow patio covering. The transition point is where most of the leaks occur. What can I do to ensure it does not rot at the joint again?
Thanks very much for the assistance.
Michael
RHMichael is offline   Reply With Quote
Old 06-18-2012, 08:04 PM   #2
Rewards Points: 14,306
Post some pictures and let us know what the roof pitches are.
Old 06-19-2012, 06:46 AM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Just roof it right to traverse the transition. It may or may not need metal there. Having said that, metal would likely be best at the transition.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
RHMichael (06-19-2012)
Old 06-19-2012, 08:02 PM   #4
The pitch of the main roof is about 5.6:7. The patio covering is more like 1:3.
Ready for Re-Roofing - Pase 1-image-2172047130.jpg   Ready for Re-Roofing - Pase 1-image-4067680388.jpg
Old 06-19-2012, 08:26 PM   #5
Thanks. I will use metal under the synthetic felt. The plan is to get that much done by the July 4.
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
New construction ready for roofing... MLO Roofing/Siding 2 11-03-2007 02:46 AM
