Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 02-26-2012, 08:13 PM   #1
Re shingle or over shingle ?
Can you overshingle a roof without major problems ?
MIKEY 43 is offline   Reply With Quote
Old 02-26-2012, 08:19 PM   #2
Can you, or should you?
Yes in most cases it can be done, but there's no way to check for bad sheathing, I hate the the way it looks, never seem to lay as flat as one layer.
I've also found there do not seem to stick down as well.
How bad is the roof you have now, what trpe roofing system do you have. Trusses, stick built. How wide are the rafters.
Old 02-26-2012, 08:25 PM   #3
long island, NY
Also I believe it reduces the life span of the new roofing layer... because it's not sitting on an ideal surface.
diy'er on LI is offline   Reply With Quote
Old 02-26-2012, 08:49 PM   #4
Exterior Construction
Windows on Wash's Avatar
For the small saving in tear off and dump fees, I do not recommend it.
Old 02-26-2012, 08:57 PM   #5
can you yes,,should you no...why...that is not how it should be done....as reasons some were already mentioned.....side thougth...tell shingle manufactor your going over existing roof....warranty void...
Old 02-26-2012, 09:43 PM   #6
RFN-4A-LVN
Roofmaster417's Avatar
Oh yes.,Someone is trying to stir the DIY demons with this post.It happens everytime someone speaks of recovers.
It is a topic that is frequent and is answered the same way by the same people who don't share the same views.
Reroofing over old shingles This is one of very many on this site.
Roofmaster417 is offline   Reply With Quote
Old 02-26-2012, 10:03 PM   #7
Gymschu's Avatar
As a DIYer who had to shovel THREE layers of shingles off his roof, I implore you NOT to overlay. You will thank me for this simple plea in 15-25 years. In some regards, shingling over one layer could be seen as good for the environment.........less shingle trash tossed into a landfill......but, like I said, what a pain trying to get 2 or 3 layers off a roof......nasty, nasty work.
Old 02-26-2012, 10:04 PM   #8
Doing This Way Too Long
Ben;s Plumbing, Can you please tell us what mfrs void the warranty on a recover?
Can you recover? Yes and it can be perfectly fine if done correctly. Check local building codes for number of layers allowed.
It is always ideal to tear it off for numerous reasons but we don't live in a perfect world.
OldNBroken is offline   Reply With Quote
Old 02-26-2012, 10:06 PM   #9
oh and by the way did he say nasty nasty work...........well if he didn't its nasty nasty work
The Following User Says Thank You to ben's plumbing For This Useful Post:
Gymschu (02-28-2012)
Old 02-26-2012, 10:16 PM   #10
RFN-4A-LVN
Old 02-27-2012, 07:17 AM   #11
Residential Roofer
Slyfox's Avatar
Manufacturers not only guarantee their materials in a lay-over but they actually give installation instructions on their websites.
If your in the Youngstown, Ohio area I can show you a dozen lay-overs in which the shingles are 20 years old "give or take" and still intact today.
I personally have seen sales reps bid tear-offs as one layer re-roofs and find later that there is two layers of existing shingles, because if there installed properly you cannot see the additional layer unless you inspect the roof hands on.
My personal home was re-roofed "tear-off" in 2010, it had two layers on it at the time, the second layer of owens corning 3-tabs was 21 years old and still not blowing off or leaking, it could have lasted an easy 5 plus years longer but because I was painting my home "changing the color scheme" I chose to re-roof it than anyhow.
That's hands on experience talking from a roofer with over 30 years in the trade.
Show me a lay-over that is lumpy, blowing off, looks bad in other ways or doe's not meet it's expected life span and I'll show you a lay-over installed by some one who didn't know what they were doing..
God Family Country Work Play
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
framer52 (02-27-2012)
Old 02-27-2012, 08:42 AM   #12
Incorrect. shingle manufacturers don't care.
framer52 is offline   Reply With Quote
Old 02-27-2012, 08:44 AM   #13
Tom Struble's Avatar
but not all shingles can be installed on an overlay,i believe ct presidentials
can't
Tom Struble is offline   Reply With Quote
Old 02-27-2012, 01:20 PM   #14
Stroudsburg Roofer
PAHome's Avatar
I would highly recommend removing the existing layer before installing the new roof. You will save money in the short run but it will cost you way more in the long run. The next time you need a roof, which if you are lucky will be in 10 years, it will cost you.
Don't think of your roof as an expense but an investment.
www.pa-homeimprovements.com
"your local roofing experts"
570-484-ROOF
PAHome is offline   Reply With Quote
Old 02-27-2012, 01:23 PM   #15
iN MY EXPERIENCE 2ND ROOFS AS LONG OR LONGER THAN FIRST ROOFS.
Of course i am only 57 and installed only around 5000 squares starting in the late 70's.
Now it has been 5 years since I have installed, but the roofs I have laid over over the years have held up well.
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 03:57 PM
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 10:05 AM
hip shingle torn and roof nail exposure timcsi Roofing/Siding 1 09-29-2010 11:09 AM
shingle vent II and hip roofs tie in dondiy Roofing/Siding 2 08-11-2008 01:40 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
