Re-shingle Help - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-14-2012, 11:18 AM   #1
re-shingle help
Hi,
My house is 13 years old. no leak.
Does roof need re-shingle now or years later?
Thanks a head.
John
JOHNJIANG is offline   Reply With Quote
Old 03-14-2012, 11:25 AM   #2
Doing This Way Too Long
Rewards Points: 532
Based on that picture, as soon as you can afford it I would seriously consider a new roof BEFORE you start having issues and causing internal damage. Those shingles are definitely on the backside of their lifespan.
OldNBroken is offline   Reply With Quote
Old 03-14-2012, 12:26 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,744
Isn't that one of those new "Green" roofs?
Old 03-16-2012, 05:34 AM   #4
DO IT RIGHT THE 1st TIME!
Replace when you have the $$$. Those shingles are about as dead as roadkill my friend. As OldnBroken said, fix it BEFORE you have the problems, its cheaper in the long run.
builttolast is offline   Reply With Quote
Old 03-16-2012, 05:51 AM   #5
Chicago, IL
Michael Thomas's Avatar
BTW, that vertical pattern of shingle failure apears to be one rafter cavity wide - it would be interesting to stick a head up there and determine why.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Shingle Damage Question Bob Deb Roofing/Siding 6 11-11-2011 03:00 PM
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 09:05 AM
hip shingle torn and roof nail exposure timcsi Roofing/Siding 1 09-29-2010 10:09 AM
shingle vent II and hip roofs tie in dondiy Roofing/Siding 2 08-11-2008 12:40 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
