Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-05-2012, 10:00 AM   #1
re-roofing an old roof over original plywood
I've heard that GAF shingles aren't reliable but that Owens Corning is the best. Is that true? What about Certainteed or other brands?
swmirsky is offline   Reply With Quote
Old 10-05-2012, 02:06 PM   #2
RFN-4A-LVN
Roofmaster417's Avatar
That same type of question is asked on about every diy,roofing and home improvement site on the internet.Probably 5 times per week.Check a few pages of threads for your answer.
Personally I prefer Certainteed.But that's just me.
Roofmaster417 is offline   Reply With Quote
Old 10-05-2012, 02:10 PM   #3
Exterior Construction
Windows on Wash's Avatar
+1 on both accounts.
Old 10-05-2012, 04:49 PM   #4
since you are ripping off everything and starting anew, it might be a good time to inspect and possibly replace any rotted roofing deck or plywood.
just make sure that you understand and negotiate how much it would cost, should this be necessary.
i completely neglected this part, thinking my roofing deck was in good shape, so I ended up paying approx. $1,000 extra (materials alone would have cost $300).
good luck
allthumbsdiy is offline   Reply With Quote
Old 10-05-2012, 09:14 PM   #5
Roofing Contractor
gafelk is no good, not even good for a dog house, they removed granules from a very important part of the shingle to cut weight and cost
owens corning better but not the greatest, they now have spots in the tar which is a step in the right direction, the fabric strip on the durations is horrible, the quality over last years durations is a lot worse.
landmark by certainteed top notch, my choice
dougger222 is offline   Reply With Quote
Manufacture History Roofmaster417 Roofing 6 02-23-2012 03:40 AM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Built Up Roofing (BUR) vs Modified Bitumen Roof (Torch Down) RacerX Roofing 4 01-31-2010 02:54 PM
roofing a dormer steve1234 Roofing 21 10-08-2007 04:02 PM
second floor addition without removing original roof coralhead1 Building & Construction 8 10-06-2006 06:56 AM
