Re-roofing house questions (Currently have Cedar shake w/ 1x6 slats)
remove all the slats,and sheathe with 3/4"plywood,if you have a soffit area to vent,vent it,regardless of windows,they should be sealed and insulated,well before you reach the soffit,and actually have solid structural supports over the tops of them called headers,so THAT won`t be a problem-make sure you use raftermatethru all the rafter spaces next to the decking(sounds like you`re talking cathedral ceiling here),and install continuous ridge vent-----NOTE:If you don`t have cathedral ceilings,you would have no problems with leaving the slats,and sheathing over them with 1/2" plywood as they add structural support,the raftermate should extend from attic to soffit,and have insulation tight to it,if you have NO soffit then use the smart vent---not clear on "radiant barrier",but I would recommend UNFACED R-30 insulation over top of your existing insulation
"If it`s worth doing,It`s worth doing right!!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
