Re-roofing A Barn - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-24-2013, 05:38 PM   #1
Re-roofing a barn
I have a 36 x 48 timber framed barn that needs a new roof. Almost all of the rafters are still sound, but a few need to be replaced. When I was younger, I would have pulled all the old tin, replaced the rotted rafters and put down new tin. Now that I am older I don't want to pull the old roof down, I would like to roof over top of the old tin.
My plan is to lay purlins across the old roof and screw/nail these into the purlins and rafters below the original roof, then screw the new roof into the new purlins. In an effort to save time, can I use a nail gun to shoot through the purlins and through the old tin roof, or, will I spend more time in the E.R. having nails pulled out of my lower legs?
BG
BG725 is offline   Reply With Quote
Old 11-24-2013, 05:44 PM   #2
Rewards Points: 14,290
Huge mistake with that whole idea.
To old to do it right (like I am) then hire it out.
Old 04-10-2014, 10:03 AM   #3
Just a follow up - did you end up replacing the entire roof?
lawrence.crush is offline   Reply With Quote
Old 04-11-2014, 05:01 PM   #4
No I haven't. I am still not exactly sure what I am going to do. I don't have the money to have somebody else do it. I am going to talk with a friend that does construction and see what his take on this is. I will let you know what I figure out.
Bob
Old 04-11-2014, 09:52 PM   #5
Metal Roofing
Rewards Points: 600
Best to remove the existing.
Any chance you have neighbors that have younger backs that could help you with it in exchange for something you could do for them?
The only other thing I can think of is going right over the metal with metal of the same profile. No issue with stripping it which makes the installation of the new much easier and safer. Just sister new rafters on to solve the bad rafter issue.
Ideally it is stripped, bad rafters replaced and re-skinned with new metal.
AndyWRS is offline   Reply With Quote
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
another barn wiring question wendell2 Electrical 10 05-29-2011 08:04 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
