Re Roof Atlanta, GA - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-01-2009, 07:48 PM   #1
Re Roof Atlanta, GA
Found that I have Hail Damage and my insurance company is paying for it. Looked at Consumer reports and owens corning oakridge 30yr AR shingles is a best buy. Where do I get 50 squares of that here in Atlanta, GA? Found a great contractor with plenty of references and even called a few...
Is there a supply house to get these? I found them at lowes for 81 a square.
Do I use galv in the valleys? I am also replacing all boots and attic power vent fans. Anything else?
blakeas is offline   Reply With Quote
Old 10-01-2009, 08:30 PM   #2
Residential Roofer
Slyfox's Avatar
The contractor you hire should be able to answer that question for you.
I'm not familiar with your area so all I could add is Google search shingle Suppliers in your area.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 10-02-2009, 05:57 AM   #3
what about ridge vents? I have 2 power attic vents but was wondering if I should intall them? seems like a pretty good way to keep the attic cool. One thing I am worried about is critters getting in through them like rats. Can that happen with them?
Old 10-03-2009, 05:51 AM   #4
as I just researched on this site, I cannot have both. sorry for the dumb question. However, what about underlayment? someone told me of the product - WR Grace Ice & Water Shield. Should I just use that in specific areas and felt in others?
on the edges of the roof - do I just use drop edges? what about the sides? Also, trying to make sure critters cant get in - it seems like i have a space between the gutters and the edge of the roof. How do I make sure there is not a space there?
Thanks for bearing with me with all these questions!
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
