Re-coating A Flat Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-16-2012, 07:48 PM   #1
Re-coating a flat roof
I own a town/row home in Baltimore with a flat roof. The new roof was put on in 2007' It was finished with top layer silver rubber coating. I was told I need to re coat it every three years.
I did some research and it seems like in order for me to apply another coat I need to:
1. Sweep the roof
2. POWER WASh
3. Apply silver coating with roller
I'm not comfortable using a power washer. Is there an alternative?
Can you recommend a product I can get from Lowe's, home depot or Ace?
chilump is offline   Reply With Quote
Old 11-16-2012, 11:30 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
If you power wash, be prepared for leaks if done improperly.
I would look up Gaco Roof.
Old 11-16-2012, 11:40 PM   #3
Thanks for the recommendation.
What other options do i have if i don't power wash?
Old 11-17-2012, 07:44 PM   #4
Metal Roofing
Rewards Points: 600
You just be very careful with where you point the nozzle and make sure your not using the zero degree tip. 0, 20, 40, 60 degree i think are what i have on mine, you would want to use the 60.
Be careful around pipe, solar tubes, skylights, dormers, chimneys ect...you can force water into those penatrations and cause a leak. Keep the nozzle tip a safe distance away from the flat, too close and you can damage it and / or make a leak.
AndyWRS is offline   Reply With Quote
The Following User Says Thank You to AndyWRS For This Useful Post:
Windows on Wash (11-18-2012)
Old 11-18-2012, 08:14 AM   #5
Just be smart about the application of power washer and how much pressure you apply to those areas that Andy mentioned.
Most power washer and house washing leaks are issues with the person on the wand.
You can make anything leak if you try hard enough.
Leakous Commencemous...
Old 11-19-2012, 06:10 PM   #6
Doing This Way Too Long
Rewards Points: 532
Stiff broom and blower. Never recommend power washing. Any non-fiber end aluminum will do...even Henry's.
OldNBroken is offline   Reply With Quote
will a flat roof always leak............. cappuccino Roofing/Siding 6 04-19-2011 05:16 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
