Range Hood Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-24-2006, 12:43 PM   #1
More Power
range hood vent
my range hood vents through the roof. I would guesstimate about 10' of ductwork. I am reroofing at the moment and I'm replacing the roof vent over that duct which is aluminum. Can I use one of the resin types over the duct from the range hood or should I stick with aluminum. Thanks for the time. By the way, the damper is either in the hood or in the duct, it is not in the roof vent.
vinman is offline   Reply With Quote
Old 07-24-2006, 07:42 PM   #2
MJW
I always put in new steel ones. You can buy the broan ones from most stores. I have in the past used a regular vent and a seperate baffle that fits into it.
MJW is offline   Reply With Quote
Old 07-24-2006, 08:37 PM   #3
More Power
thanks for the reply mjw.
Old 05-06-2012, 09:54 PM   #4
slate roof venting
Does anyone know if venting through a slate roof requires a different approach than more conventional roofing shingles?
rich12072 is offline   Reply With Quote
Old 05-07-2012, 12:37 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
Yes.
Seeing as you do not want to disturb slate with any regularity, it is recommended that you use a more permanent option as compared to standard rubber roof boots.
Old 05-07-2012, 01:53 PM   #6
Thanks Windows On Wash. Can you tell me what should be used instead and where I can get the materials needed?
Old 05-07-2012, 02:23 PM   #7
Rewards Points: 880
Look for some posts by tinner666 and pm him.
He is a slate expert.
Vent Hood CFM's wease Appliances 14 04-20-2012 08:00 AM
custom range hood weekend warrior 1947 Carpentry 5 05-25-2011 07:59 PM
noise from vicinity of range hood squished18 HVAC 8 04-20-2010 01:15 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 05:06 PM
Island Hood Vent Centering Problems Dana Remodeling 2 07-13-2005 08:37 AM
