Rake Trim Issue - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-27-2013, 12:42 PM   #1
Rake trim issue
I just put up the last sheet of metal which is 12.5" wide and the ridge line up with where the rake trim would rest. If I install on top of the ridge the the rake doesn't cover the gable end. If I cut back before the ridge then the rake won't cover the roofing. If I move the rake to the outside of the ridge then it sticks out to far. I'm not sure what my options are. Any suggestions?
sleseman is offline   Reply With Quote
Old 10-27-2013, 01:40 PM   #2
Rewards Points: 2,238
Show us a picture! rossfingal
rossfingal is offline   Reply With Quote
Old 10-27-2013, 03:43 PM   #3
Roofmaster
Rewards Points: 2,210
Huh? Yeah, show us a lot of pictures.
Old 10-27-2013, 03:47 PM   #4
Rewards Points: 13,722
Makes little since to me.
A 12-1/2 wide piece of sheet metal? Do you mean coil stock?
That's going to buckle big time.
Old 10-27-2013, 04:02 PM   #5
Here is the end I am trying to finish and my rake trim. I'm considering pulling off the 2x6 I put up, cutting the roof back to the white 2x4 and then pull that off and put the 2x6 in it's place. This is a 70+ year old garage.
Old 10-27-2013, 04:15 PM   #6
More pictures including the finished ends with the rake trim. Shortening up the overhang would allow me to cut that last piece back to the rib but I'm hoping there is an easier answer. All pieces were special order from Menard's.
Rake trim issue-img_20131027_160730.jpg   Rake trim issue-img_20131027_160437.jpg   Rake trim issue-img_20131027_160921.jpg   Rake trim issue-img_20131027_160829.jpg   Rake trim issue-img_20131027_161002.jpg
Old 10-27-2013, 04:16 PM   #7
So where's the fascia to cover up the rafter tails?
You left the 2 X 4's hanging out to far to use that cap correctly.
Why was the rake not cut at an angle to match the rafter?
Going to need a coil stock break to custom make that size metal.
Old 10-27-2013, 04:29 PM   #8
Haven't put the facial up yet. The edge of the roofline tapers in from the peak so trying to make it square they stick out a little.
Old 10-27-2013, 04:42 PM   #9
They needed to be even with the fascia so the metal fits tight against it. If not insects, squirrels and bats can get in.
The lower fascia needed to go on first and the gable runs past it. if not your going to be leaving the exposed end grain exposed right where water is going to be running down it.
Rafter tails should have been cut so there at a 90 deg. angle to the wall of the house before the roof went on.
What's the plans on the old asbestoses siding? If it's going to be replaced it should have been removed enough to install vinyl or aluminum soffits.
Old 10-27-2013, 05:06 PM   #10
Was going to use the multi tool to cut the ends of the 2x6 to match the 2x4. It's a shingle type siding, are you saying that's asbestos? I sure hope it isn't considering the amount of cutting I did on it to clean up the bottom. I cut it off at the ground and put a treated 2x10 down. My house has asbestos tiles but didn't know the garage ones were as well since they look like shingles. I will be putting 4x8 sheet siding over it next summer. I've decided to take the 2x6 off and cut everything back.
Rake trim issue-img_20131027_165609.jpg   Rake trim issue-img_20131027_165651.jpg   Rake trim issue-img_20131027_165732.jpg   Rake trim issue-img_20131027_165854.jpg   Rake trim issue-img_20131027_165813.jpg
Old 10-27-2013, 05:36 PM   #11
Sorry, but that's asbestos.
Old 10-27-2013, 05:37 PM   #12
Rewards Points: 646
Looks like asbestos core asphalt to me, low risk much like the siding. Pain to dispose of, wear gloves and a mask.
My family installed thousands of houses worth of the stuff, and my penance is dealing with it 50 years later.
PatChap is offline   Reply With Quote
what is the purpose of metal roof rake trim ugabulldog Roofing/Siding 5 09-15-2013 09:09 PM
Type nails? - wooden trim into cement board Easypick Carpentry 5 07-21-2013 03:16 PM
Door & Window Trim / Casing Overhaul - Craftsman Style lohryx5 Remodeling 7 07-11-2013 07:52 AM
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 01:01 PM
Installing ceiling trim with uneven ceiling. capslock Carpentry 3 03-20-2010 11:53 PM
