Rake Drip Edge - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-06-2011, 02:00 PM   #1
rake drip edge
More questions from a beginner.
When installing drip edge on the barge board, or rake board, or whatever your term of choice is for it, should it be installed flush to the board, or should there be a gap? It seems like if it was flush, water could drip down the barge board and then get in behind the siding. Which brings up my second question, should there be caulk, or other barrier, between the siding and the barge board? I've attached a diagram for clarification.
Thanks for all the help thus far...
diyroofer is offline   Reply With Quote
Old 09-06-2011, 04:34 PM   #2
kwikfishron's Avatar
Rewards Points: 824
Your dip edge shouldn’t be a straight 90 deg. It should kick out at the bottom.
There should be caulking behind the last coarse of siding, if not it should be caulked.
kwikfishron is online now   Reply With Quote
Old 09-06-2011, 05:00 PM   #3
Rewards Points: 824
Be sure to run the felt out to the edge of the barge. You’re not showing that in your drawing.
Old 09-06-2011, 05:01 PM   #4
Thanks for the reply. My current roof has straight 90 degree flashing over the rake edge and it's butted against the barge board. It seemed like there was a better way. I assume it isn't hard to find flashing like pre-fabricated like you described? Or do you have to bend the kickout yourself?
Old 09-06-2011, 05:05 PM   #5
Yes, I will felt to the edge, under the metal. What are your thoughts on I&W up the rakes? It could be folded over the edge of the roof deck and slightly down the barge board behind the drip edge for extra protection, but it seems like it might be overkill.
Old 09-06-2011, 05:42 PM   #6
Rewards Points: 824
The metal I described is just stock stuff, and any lumber yard, roofing supply and some hardware stores will have it.
You don’t need fold over the underlayment, that’s what the metal is for. I would fold it up where the roof meets the wall though.
The Following User Says Thank You to kwikfishron For This Useful Post:
diyroofer (09-06-2011)
Old 09-07-2011, 10:49 PM   #7
Rewards Points: 1,542
Either bend the kick out yourself or bend the entire flap out a little so the angle is a little more than 90 degrees. (Leave a gap of about 3/16 inch between the bottom edge of the drip edge or flashing and the barge board.)
The Following User Says Thank You to AllanJ For This Useful Post:
diyroofer (09-07-2011)
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing/Siding 6 07-13-2015 09:04 AM
Ice and Water Shield under drip edge? sutterml Roofing/Siding 10 07-11-2011 05:04 AM
roof drip edge billygale Roofing/Siding 9 10-24-2010 02:19 PM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 10:49 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
