Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-04-2012, 02:57 PM   #1
raising shed roof pitch
i want to add 4 ft of height to an existing wall to put a shed pitch roof on the structure. how do i tie this 4ft kneewall into the existing wall so it doesn't act like a hinge when the shed rafters go up?
mattt is offline   Reply With Quote
Old 01-05-2012, 05:55 AM   #2
Retired carpenter
That wouldn't be called a kneewall, but an afterthought.
Nail full length (full height) studs to both the upper and lower walls.
abracaboom is offline   Reply With Quote
Old 01-05-2012, 09:29 AM   #3
I was hoping to avoid tearing into the already finished wall-- thus not being able to run full length studs up to tie into the 4 ft added height. Any thoughts?
Old 01-05-2012, 10:08 AM   #4
Disabled wood vet
titanoman's Avatar
The rafters won't let the "knee wall" "hinge". You will be fine.
Edit: I am wrong. That will be a bouncy wall unless you put joists in it. Are you after more head-room or a higher pitch for shingles/water shedding?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-05-2012, 12:21 PM   #5
just trying to match the roof line of the rest of the house.Also, the ceiling will now be cathedral(thus the reason for the shed pitch)
Old 01-05-2012, 12:24 PM   #6
Disabled wood vet
titanoman's Avatar
You can get away with a pony wall if you run a couple joists to tie in the "hinge" point. But you already know that.
Old 01-05-2012, 04:17 PM   #7
Pro Slate Roofer
tinner666's Avatar
Run collar ties about 4' long. It'll give you about 2-1/2' or so of flat ceiling at the upper end. Put your can or track lights there too if your want.
(The collar ties shoud run from all the way inside your 4' wall and the longest point should be right at the roof sheathing.)
Frank
tinner666 is offline   Reply With Quote
Old 01-05-2012, 04:34 PM   #8
Disabled wood vet
titanoman's Avatar
Is there going to be any sheathing on the outside that you can run 8 footers from the top down? That would really stiffen things up.
Old 01-05-2012, 05:35 PM   #9
Thanks for the responses! The 4ft collar tie idea would look good and work too-- but the ceiling' had to' match, just decided to tear into the wall instead and run full studs at intervals.. the can of worms is open. Thanks again.........
Shed dormers & existing roof pitch M0hoa5md Building & Construction 8 08-15-2011 06:53 PM
shed roof over old deck bluegrass General Discussion 3 09-12-2009 02:03 PM
Shed roof stubits Roofing 1 07-14-2009 08:48 PM
Addition and Roof Replacement lebeld Roofing 4 01-04-2009 07:11 PM
Building Roof over Roof, changing pitch Thomas O Roofing 7 03-05-2008 10:51 PM
