raising front porch columns
If it is sagging that much, you might wwant to think about rebuilding it.
Is it rotted? Undersized lumber? Not doubled up 2x? Posts too far apart? Something seems to have gone awry if the sag is really extreme.
I have found that when framing lumber has settled so much, it can crack/break/fail if you try to jack it up.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
