Raised Shingles A Concern? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-12-2011, 04:10 PM   #1
Raised shingles a concern?
While cleaning my gutters I noticed that a certain shingle, and the one on top of it, appear to be raised off the roof a bit (see circled area of picture).
Is this a concern? If so is there a simple fix? I know nothing about roofing unfortunately and would really appreciate any thoughts.
thanks!
ConfusedDave is offline   Reply With Quote
Old 08-12-2011, 10:25 PM   #2
No, not really a big concern if that is the only aesthetic concern.
If you can remove the nail at the side gable edge of that shingle, (To do so, you must un-nail the shingle above it too), then you may be able to press it down in plae and re-nail it.
Or, you can lay something like a 2" x 6" on top of it with some weighted ballast, such as a small sand bag and see if it keeps it down permanently.
Ed
Ed the Roofer is offline   Reply With Quote
Old 08-13-2011, 11:10 AM   #3
Thank you for the reply, I appreciate the help.
I noticed you categorized the problem as an aesthetic concern. Is it therefore reasonably safe to assume that if I leave things as is that I won't experience roof problems?
As far as visuals go, this is only an issue I notice when I clean my gutters once or twice a year...I don't notice it from the ground and therefore would rather not risk going up on the roof if this doesn't pose a true problem.
Again, thank you for taking the time to help me.
Old 08-13-2011, 07:30 PM   #4
Gymschu's Avatar
Rewards Points: 838
It is fairly minor although you would want to get that nail sunk so wind doesn't catch that shingle and blow it off. Also, a wind driven rainstorm could blow water up under that shingle...........unlikely to be sure, but why take chances.
Old 08-17-2011, 04:57 PM   #5
Looks like the nail underneath the tab is coming up...you can take a flat pry bar, put it under the shingle tab and on top of the offending nail...then carefully bang it back down with a hammer(on top of the tab)..this will be a temp fix at best, it will eventually work it's way back up again...remember...carefully...you don't want to have the nail puncture the shingle
Denzo is offline   Reply With Quote
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
Corner shingles along eave are raised up sophie10 Roofing/Siding 3 10-24-2010 10:45 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
New Roof - Concern Over Seemingly Poor Workmanship cjakins Roofing/Siding 16 11-24-2009 06:38 AM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 03:42 PM
