Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-02-2012, 02:57 PM   #1
Rain water coming in through bathroom exhaust fans
Whenever we get a hard rain, water gets into the bathroom exhaust fans and drips down into the room... Any thoughts on hoe to fix this issue?
Hilary is offline   Reply With Quote
Old 10-02-2012, 05:01 PM   #2
"Nail-Bender"
Post a picture(s) of where the vents go through the roof.
Close up and back a little.
rossfingal
rossfingal is offline   Reply With Quote
Old 10-02-2012, 05:06 PM   #3
Experienced
Jackofall1's Avatar
I am not to sure you could use a hoe to fix a leaking vent, but, a better description of where the vents are and if you can a picture or two it would certainly help us help you.
Mark
Hot water coming through cold water line mrdojo Plumbing 0 01-26-2012 05:19 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Multiple bathroom exhaust fans dpreznik HVAC 17 08-30-2007 01:09 PM
2 bathroom exhaust fans to one outside vent pipe? CGofMP HVAC 2 03-25-2005 10:45 PM
