Rain Water Collection To Above Ground Barrel Via Underground Hose - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-01-2012, 11:20 PM   #1
Rewards Points: 35
Rain water collection to above ground barrel via underground hose
I have seen an advertised rain collection system that has an entry high up in the downspout with a hose from there down the downspout and into the ground. The hose goes underground to a distant point where it exits the ground and rises to empty into the top of a distant barrel. The entry high up in the downspout allows the rain water to siphon to a barrel on the property where the ground is at a higher elevation than the ground at the downspout. That is attractive because the barrel can be above the garden area and the water gravity feed to the garden. I do not need water in freezing weather, but if I set this up as shown in the advertisement (which I cannot now find), the hose will freeze every winter, and I doubt any hose can take that for long. I could use stronger PVC and really bury it, but it will still remain full of water below the level of the top of the rain barrel, and freeze all the way down to the freeze line at both vertical portions, even if the "horizontal" run is below the freeze line. I wonder if PVC would survive freezes.
Anyone tried this method of diverting rain water to a distant storage without pumps? As advertised, it appears the funnel in the downspout does not collect all the water, so if the hose were to plug with ice, water could spill around the entry funnel and exit the downspout as usual.
EdLank is offline   Reply With Quote
Old 06-01-2012, 11:23 PM   #2
Rewards Points: 6,652
You are talking about something that has been around for centuries, if not the dawn of man kind. The materials may have changed, but the process remains the same.
is water conservation inside the shower head or the shower hose? vcreation Plumbing 1 11-11-2011 06:20 AM
garden hose water spillage: damage to pipes, huge water bill? cluelessDIYer Plumbing 5 06-26-2010 11:42 AM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Sanity check - water collection for irrigation - from creek bed So cal Man Landscaping & Lawn Care 2 08-14-2008 06:16 PM
