Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-24-2012, 05:19 PM   #1
rain diverter install
I want to use a J channel rain diverter under the shingles on my patio roof. How do I avoid moisture under the shingles when/if we have snow? Have seen this done but they didn't address this issue on the video. Perhaps it is a non issue and I am just over thinking this.
cbdiy is offline   Reply With Quote
Old 09-24-2012, 09:57 PM   #2
I hope your not thinking about using a piece of vinyl J moulding for this?
Where the deverter gets nailed to the roof it needs to be at least 3" up under the edge of the shingle.
A simple L shaped piece of coil stock is the simplest way to do it.
I do a 1/2 seam, then make the next bend at 1" and cut it off at 3 or 4".
The seam adds strength to the raised area.
New deeper kitchen sink install problem jmalcolm Plumbing 3 04-27-2011 11:48 AM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 03:18 PM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 10:02 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
