Rain - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-29-2011, 01:25 PM   #1
Rewards Points: 306
Rain
I had my roof re-shingled a couple of years ago. Great job, no complaints. I noticed during a recent rain that at one point along the dripline the water flowing off the shingle lip actually curls around back underneath to run down the facia board. This seems odd since there is a good 3/4" of shingle overhang on a pitched roof.
I am thinking there may be some kind of hydrophobic product I could paint on underneath the lip to prevent that.
tns1 is offline   Reply With Quote
Old 11-29-2011, 05:00 PM   #2
Rewards Points: 252
This is why they install metal drip edge.
shazapple is offline   Reply With Quote
The Following User Says Thank You to shazapple For This Useful Post:
MJW (11-29-2011)
Old 11-29-2011, 07:22 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,234
Water has a given surface tension and this tendency for water to actually flow uphill is what a drip edge/apron is designed negate.
Old 11-29-2011, 07:59 PM   #4
Rewards Points: 268
Do you live in an alternate universe where water defies gravity?
packer_rich is offline   Reply With Quote
Old 11-29-2011, 08:18 PM   #5
I wish.
For the original poster, the water does not actually defy gravity by itself but it can go toward the fascia board via capillary action and the high polarity of water draws molecules to another molecule.
Ever seen a bug run across a lake...surface tension.
Hence the way that water can creep up a surface and the same concept that reverse curl gutter caps are based around.
Old 11-30-2011, 06:55 AM   #6
Residential Roofer
Slyfox's Avatar
I don't see where the poster said there was no drip edge.
Even with drip edge/gutter apron properly installed the water can and will still travel back to the facia, now if it finds a way behind the facia then there's a problem.
If you have gutters they should catch that water, if you don't than you should keep your facia painted, sealed or wrapped properly in aluminum, depending on the type you have.
You don't want to paint the portion of the shingle you see hanging over the edge (surface or underneath) because that will eventually cause other issues.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 11-30-2011, 11:14 AM   #7
Rewards Points: 306
The upper edge of the facia board has aluminum drip edge/protection covering the edge and hanging down maybe 2" with a slight flair out from the face of the facia. The shingle overhangs this about 1", and is the only real drip edge. A gutter would not change the wicking action of the rain unless it were sealed to the underside of the shingle or tucked underneath the aluminum.
This wicking only happens at one spot where there is a steady stream of water. I suppose I could place additional aluminum to extend the drip edge slightly at that spot, or just live with it. It will eventually stain the facia.
Siding and rain screen Andee77 Carpentry 1 09-08-2011 08:28 AM
Gutterless or Open Field Rain Collection q127238 Landscaping & Lawn Care 0 08-18-2010 09:48 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 06:57 AM
Rain Gardens Colchicine Green Home Improvement 2 02-13-2009 06:35 AM
Moisture in walkout basement after rain storm dannox02 Building & Construction 2 01-24-2006 12:45 PM
