Rafters 32" On Center - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-14-2010, 10:05 PM   #16
Commercial Roofing
AaronB's Avatar
How old is this cottage?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-15-2010, 08:51 AM   #17
It was built in the 60's or 70's i believe
huai is offline   Reply With Quote
Old 04-15-2010, 11:04 AM   #18
Commercial Roofing
AaronB's Avatar
And the engineering at the time isn't sufficient?
Old 04-15-2010, 11:06 AM   #19
Commercial Roofing
AaronB's Avatar
I had a nother post that must have been deleted.
An A frame building is usually 18/12 or 20/12 roof pitch and would not hold snow nor a person. I think this is one of the benefits of an a frame building.
{none of your posts have been deleted - Dave}
Old 04-15-2010, 07:58 PM   #20
Yes this is 20/12
I had to put up roof jacks and a 2x10 to work on the roof
Last time I went up during the winter, there was snow on the roof (I'd say 6 inches) compared to 3 ft on the ground.
Old 04-16-2010, 10:30 PM   #21
Rewards Points: 1,910
If it hasn't caused any problem for 40 to 50 years I can't imagine why you would spend any time fixing something that isn't broke. But if you really need a project to keep you off the streets (LOL) then then just apply some construction adhesive to the top of the rafter to glue it to the sheathing rather than trying any nails.
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 06:50 AM
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 06:56 AM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 10:56 AM
Drilling into Center Beam leted_82 Building & Construction 2 03-06-2007 08:52 PM
