Rafter Vents And Insulation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-21-2010, 03:15 PM   #1
Rafter Vents and Insulation
Hi guys, I've got a question about insulating the rafters in a cathedral roof between a knee wall and collar ties. The rafters are 2x6's and I've installed rafter vents in every one, the vents are 1 1/4" high. My question is, can I still lay down insulation meant for 2x6 studs over top the vents or will I have to do either:
a) lay down insulation for 2x4 studs
or
b) add 1 1/4" furring strips to the rafters?
picture of r22 insulation layed over top a the rafter vent
nofx1981 is offline   Reply With Quote
Old 02-21-2010, 05:10 PM   #2
You can still 2x6 insulation so long as it does not crush that vent
Usually compressing insulation reduces the RValue
The Following User Says Thank You to Scuba_Dave For This Useful Post:
nofx1981 (03-08-2010)
Old 02-23-2010, 12:21 PM   #3
Commercial Roofing
AaronB's Avatar
You could use SPF and forget about your worries.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 02-23-2010, 12:48 PM   #4
Thanks for the replies, I'm gonna stick with the 2x6 insulation I started with
Old 02-25-2010, 12:41 PM   #5
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Make sure you use ridge vent on that. Plus you will not lose all that much r value when you compress it that much.
Big N8 is offline   Reply With Quote
Old 03-09-2010, 02:23 PM   #6
already ridge vented
Old 03-09-2010, 04:26 PM   #7
Commercial Roofing
AaronB's Avatar
That configuration is not doing what you need it to do... only foam insulation can do that.
Old 03-10-2010, 09:42 AM   #8
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
So are you saying every roof with a vaulted/cathedral ceiling needs to have spray foam?????
Old 03-10-2010, 12:39 PM   #9
Commercial Roofing
AaronB's Avatar
Well, for maximum insulating value according to current code, yes.
Old 03-10-2010, 12:40 PM   #10
Commercial Roofing
AaronB's Avatar
Vaulted and Cathedral ceilings are not the same thing... so no, but fiber insulations are a HUGE waste of money.
Old 03-10-2010, 12:44 PM   #11
R22 is under the required insulating value for a roof here
Here R30-R38 is the Min allowed
You will be paying much more in the long run in heating costs
Old 03-10-2010, 01:12 PM   #12
The attic won't be heated, just being used for storage. I'm trying to minimize the extreme temperatures we see in the summer and winter up there.
Old 03-10-2010, 01:38 PM   #13
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
So it is the R value not the type of insulation that matters????
Old 03-10-2010, 04:47 PM   #14
Different types of insulation will have different R values, R values is what typically matters when you're looking at building codes.
Old 03-10-2010, 09:09 PM   #15
Commercial Roofing
AaronB's Avatar
True, to an extent, nofx1981
To understand thermal efficiencies, we must first try to understand how R value is measured/determined. For this, I have a nice article that I have stolen from the web. Let me go find it....
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Rafter vents & insulation question k.kuenn Roofing/Siding 15 01-30-2011 12:34 AM
Soffit vents on older houses with "curved" ceilings Labman101 Roofing/Siding 2 02-07-2010 11:33 PM
Insulation Batt Blocking Soffit Vents mikebal Roofing/Siding 8 07-05-2008 05:58 PM
