-   -   Rafter Vents and Insulation (http://www.diychatroom.com/f9/rafter-vents-insulation-65011/)
nofx1981 02-21-2010 02:15 PM
Hi guys, I've got a question about insulating the rafters in a cathedral roof between a knee wall and collar ties. The rafters are 2x6's and I've installed rafter vents in every one, the vents are 1 1/4" high. My question is, can I still lay down insulation meant for 2x6 studs over top the vents or will I have to do either:
a) lay down insulation for 2x4 studs
or
b) add 1 1/4" furring strips to the rafters?
picture of r22 insulation layed over top a the rafter vent
http://i262.photobucket.com/albums/i...Rafter0001.jpg
Scuba_Dave 02-21-2010 04:10 PM
You can still 2x6 insulation so long as it does not crush that vent
Usually compressing insulation reduces the RValue
AaronB 02-23-2010 11:21 AM
You could use SPF and forget about your worries.
nofx1981 02-23-2010 11:48 AM
Thanks for the replies, I'm gonna stick with the 2x6 insulation I started with
Big N8 02-25-2010 11:41 AM
Make sure you use ridge vent on that. Plus you will not lose all that much r value when you compress it that much.
nofx1981 03-09-2010 01:23 PM
already ridge vented :thumbsup:
AaronB 03-09-2010 03:26 PM
That configuration is not doing what you need it to do... only foam insulation can do that.
Big N8 03-10-2010 08:42 AM
So are you saying every roof with a vaulted/cathedral ceiling needs to have spray foam?????
AaronB 03-10-2010 11:39 AM
Well, for maximum insulating value according to current code, yes.
AaronB 03-10-2010 11:40 AM
Vaulted and Cathedral ceilings are not the same thing... so no, but fiber insulations are a HUGE waste of money.
Scuba_Dave 03-10-2010 11:44 AM
R22 is under the required insulating value for a roof here
Here R30-R38 is the Min allowed
You will be paying much more in the long run in heating costs
nofx1981 03-10-2010 12:12 PM
The attic won't be heated, just being used for storage. I'm trying to minimize the extreme temperatures we see in the summer and winter up there.
Big N8 03-10-2010 12:38 PM
So it is the R value not the type of insulation that matters????
nofx1981 03-10-2010 03:47 PM
Different types of insulation will have different R values, R values is what typically matters when you're looking at building codes.
AaronB 03-10-2010 08:09 PM
True, to an extent, nofx1981
To understand thermal efficiencies, we must first try to understand how R value is measured/determined. For this, I have a nice article that I have stolen from the web. Let me go find it....
