Rafter Tails? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-02-2009, 02:50 PM   #1
Rafter Tails?
I have several rafters that have some rot at the very ends of them. (is this called the rafter tail?). It's only about 2-4" on about 6 of them from a failing California gutter system. What can I do to repair them? Can a sister them up to where they enter the wall deck? Any advice would be greatly appreciated. Thanks
mike5326 is offline   Reply With Quote
Old 07-02-2009, 04:45 PM   #2
Oldguy
Rehabber's Avatar
Dry rot is caused an organism that needs to be killed/removed. Remove as much damaged wood as possible, (Wire brush will remove most of it if it's not bad.) Cut it out if it's more extensive. Then treat with a boric acid solution. Repair with an epoxy wood filler or sister/replace as necessary. (Bondo will also work well instead of an epoxy wood filler in this application)
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 07-02-2009, 06:11 PM   #3
Rewards Points: 258
The use of bondo or epoxy seems to be more of a cosmetic fix. Sistering will promote structural integrity.
retired guy 60 is offline   Reply With Quote
Tags
rafters
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
rafter questions - structural rtoni Carpentry 11 09-13-2007 06:40 AM
