Rafter Tail Caps? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-18-2012, 11:49 AM   #1
Rafter tail caps?
Does anyone know what this product is called and where I could find them? Or are they some sort of custom made item?
weekendwarrior9 is offline   Reply With Quote
Old 09-18-2012, 11:53 AM   #2
Rewards Points: 13,256
I'd have a sheet metal shop make some up out of copper and use copper nails to attach them instead of those ugly caps.
Windows on Wash (09-18-2012)
Old 09-18-2012, 01:21 PM   #3
Yeah, I hoping that these caps were just painted white, that I could get them in copper and get them weather naturally.
Was just wondering if these things were an actual product somewhere or had a proper name I could reference them by when talking to a fabricator.
Old 09-18-2012, 11:24 PM   #4
Registered User
Rewards Points: 5,204
I'd punch a small drainage hole in the bottom flap. The beam gets wet, sun warms the beam, metal warms faster/more than the wood, moisture in beam is drawn (capillarity due to temperature differences) to the metal, can't air-dry, rots. I've pulled a dozen or so due to just that. Punch the hole from inside-to-out before installing.
Gary
Old 09-20-2012, 07:02 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
I would edge prime the cut ends as well.
Can't hurt and it will help slow any moisture absorption.
Old 09-20-2012, 08:04 PM   #6
Registered User
The paint would slow the drying as well, possibly blocking the moisture from exiting there, encouraging it to travel toward the warm house (or just saturate next to the beam cap). There is "no win" with wood ends exposed to exterior. The beams/joists/rafters act as heat sinks- moving your paid-for heat outdoors or reverse in warm climates; bringing the heat in to your cooled room. With solid wood at R-1.25 per inch, that's a whooping R-4.4 or R-7 in the wall (usually right at the ceiling where is is toasty warmer than below)!
Gary
Open rafter tail trim out and ventilation Nutchie Building & Construction 4 06-23-2012 10:53 PM
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 11:26 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 08:55 PM
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 12:40 PM
rafter tail rott mohamie Roofing/Siding 8 09-27-2006 06:28 PM
