Rafter Spacing For Tarp Covered Canopy - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-25-2014, 09:49 PM   #1
Question
Rafter spacing for tarp covered canopy
How far apart can I space wood rafters when it is only going to be covered with "chicken wire" and large tarps for a large outdoor canopy ?
(we are in South Carolina and heavy snow is very rare, though it did happen recently)
DIY SC is offline   Reply With Quote
Old 02-26-2014, 05:25 PM   #2
Canopy
It depends on the roof style. If it is a straight gable, I would still put them no less than 2 foot apart. That is because - and again other factors such as the thickness of the tarp used on the roof - the tarp could sag if they are too far apart.
TedLeger is offline   Reply With Quote
Old 03-18-2014, 10:31 PM   #3
Thanks for the advice, I was busy for a while but got a start on the project and wanted to share a photo. (the rafters are being spaced 2 feet apart)
Old 03-18-2014, 11:29 PM   #4
roof
Ok, I see what you are doing now. What is that for exactly?
Old 03-19-2014, 01:15 AM   #5
Actually it is to give my Border Collie a large area to exercise in no matter what the weather (about 80 feet long by 16 feet wide)
(she likes for me to be in there also to throw Frisbees and balls, she does not like to exercise by herself so I get some exercise too
Here in South Carolina we can go thru times where it can sometimes rain over a several day period and Border Collies get frustrated when they have pent up energy from not being able to run for a few days. (she is an indoor dog, but usually gets plenty of outdoor time)
That is why I decided to cover her yard with some large tarps, it has the added benefit of giving my dog and I some shade on the hot summer days
Originally I had a 3/4" PVC frame curved over the tops of the fence posts, but a very rare heavy snow collapsed about 2/3 of it so I am switching to a wood frame. (fortunately I had a fair amount of treated lumber sitting around from a past project we decided to put off for now)
I had put back up half of the PVC framing in the meantime so at least half the yard would stay dry and shaded, but later added extra frame support that was needed because strong wind gusts were able to flex the PVC too much and cause a collapse. It is two vertical 1 1/2 PVC pipes fastened to underneath the top of the PVC frame.
I will eventually extend the wood frame further and further till the entire thing is a wood frame.
Here are some photos of the original all PVC construction as well as some current photos of how it is as of right now -
(on the inside views you can see at the far end where I am starting the wood frame)
Rafter spacing for tarp covered canopy-canopy-frame-7.jpg   Rafter spacing for tarp covered canopy-canopy-tarp-1.jpg   Rafter spacing for tarp covered canopy-canopy-support.jpg   Rafter spacing for tarp covered canopy-canopy-wood-frame-3.jpg   Rafter spacing for tarp covered canopy-canopy-wood-frame.jpg
The Following 2 Users Say Thank You to DIY SC For This Useful Post:
MTN REMODEL LLC (04-30-2014), oh'mike (03-19-2014)
Old 03-21-2014, 09:32 PM   #6
rafter spacing
Ok, yeah, 2 foot apart would be fine for that.
Old 03-26-2014, 07:01 PM   #7
Here's a couple pics to update my progress so far -
Old 04-23-2014, 06:43 PM   #8
Ok, meant to post an update sooner, but been busy trying to get other yard stuff done
Here are some photos that show the finished (for now) wood frame.
(I have to do a separate reply to include the rest of the photos)
(eventually I plan to extend the wood frame all the way, but I am done for right now
Rafter spacing for tarp covered canopy-1-canopy-.jpg   Rafter spacing for tarp covered canopy-1-canopy-b.jpg   Rafter spacing for tarp covered canopy-1-canopy-c.jpg   Rafter spacing for tarp covered canopy-1-canopy-d.jpg   Rafter spacing for tarp covered canopy-1-canopy-e.jpg
Old 04-23-2014, 06:46 PM   #9
Here are the rest of the photos, these show the finished (for now) frame with the tarp roof attached.
Rafter spacing for tarp covered canopy-1-canopy-g.jpg   Rafter spacing for tarp covered canopy-1-canopy-h.jpg   Rafter spacing for tarp covered canopy-1-canopy-i.jpg   Rafter spacing for tarp covered canopy-1-canopy-j.jpg   Rafter spacing for tarp covered canopy-1-canopy-k.jpg
Old 04-23-2014, 08:45 PM   #10
Good Work
Glad you went with the 2 foot rafters. The chicken wire definitely made a difference as well. You collie should like that large space.
The Following User Says Thank You to TedLeger For This Useful Post:
Windows on Wash (04-23-2014)
Old 04-25-2014, 04:45 PM   #11
That's a pretty sweet structure but blue tarps will deteriorate from sun alone in less than a year, at least here in South Florida. Now that you have a frame roof why not put up a sheathing roof deck and shingles for a more permanent roof? Might need some structural reinforcement if you do.
suobs is offline   Reply With Quote
Old 04-25-2014, 10:45 PM   #12
Thanks for the suggestion, but amazingly enough I have had similar tarps last longer.
The main reason for tarps is that I have been on a very tight budget as far as what extra funds I had available for this project.
I have considered as a future possibility of switching to a more permanent but still relatively lightweight roofing material when the budget would allow, perhaps something like fiberglass sheets might be one possibility.
Old 04-30-2014, 06:14 PM   #13
[QUOTE=DIY SC;1342334]Thanks for the suggestion, but amazingly enough I have had similar tarps last longer.
The tarps will be fine. They definitely will last longer than 1 year. I have had tarps sit on the ground that lasted way longer than that.
Old 04-30-2014, 06:26 PM   #14
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,448
Hey SC..... Nice job.... and nice job takeing care of that pup
Your pics were interesting..... BUT YOU NEED MORE OF YOUR PUP...
Best
MTN REMODEL LLC is online now   Reply With Quote
Old 04-30-2014, 07:08 PM   #15
Best
Thanks !
Since you asked for more pics of my pup -
Rafter spacing for tarp covered canopy-feb-2014.jpg   Rafter spacing for tarp covered canopy-march-2014.jpg
Tags
rafter tarp snow roof
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-18-2012 12:46 AM
rafter spacing for snow loads ellsten Roofing/Siding 4 12-15-2011 03:56 PM
Shed style porch rafter span and spacing sjjacks Building & Construction 3 05-05-2009 07:17 PM
Joist, rafter, and stud spacing for shed? Badfish740 Building & Construction 2 10-27-2008 05:12 PM
rafter spacing Clutchcargo Building & Construction 5 08-11-2007 03:14 PM
