Rafter Spacing For Snow Loads - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-14-2011, 12:05 AM   #1
rafter spacing for snow loads
am going to build my own cabin where it snows. can I still use 2x6's for rafters if I space them on 16" centers? or should I use 2x8'?
ellsten is offline   Reply With Quote
Old 12-14-2011, 01:45 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
2x8's. Refer to building codes.
titanoman is offline   Reply With Quote
The Following 2 Users Say Thank You to titanoman For This Useful Post:
concretemasonry (12-15-2011), ellsten (12-14-2011)
Old 12-14-2011, 06:53 AM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
16"oc is correct, but the size depends on the lenght, pitch of the roof, and your location.
The load on 2x6's is much different for the same lenght if one roof is pitched at 12/12 and the other is 5/12, and even more noticeable if it's a flat roof.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Old 12-14-2011, 08:17 AM   #4
Residential Roofer
Slyfox's Avatar
Building it yourself as in ordering prefabbed trusses and setting them your self?
If that's the case the lumber yard rep will better answer your question because he/she will know the local codes.
Stick framing it yourself?
I would still start by asking the local lumber yard rep for local codes.
I myself have never seen anyone stick frame with less then 2x8's, but, I'm a roofer not a framer.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
Old 12-15-2011, 02:56 PM   #5
43 years in construction
Arkitexas's Avatar
There is not a simple answer to such a question without a trained person viewing all the conditions. Taking advice based on the scanty information you provided is unwise. You are dealing with heavy structural stuff that can fall and kill.
2x6, 2x8, 2x10, 2x? depends on the span of the rafters, the c/c spacing of the rafters, the span capability of the decking, type of roofing material, and the calculated live and dead loads. Most codes include a table of minimum requirements for various spans at various parts of the country. The local code official may have his own acceptable minimum. A local professional framer can also provide safe advice. Lastly you can hire an engineer or architect to calculate the rafter size based on the above information (their solution may legally differ from the prescriptive codes tables).
Rick
Arkitexas is offline   Reply With Quote
The Following User Says Thank You to Arkitexas For This Useful Post:
Gary in WA (12-17-2011)
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 10:26 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
Shed style porch rafter span and spacing sjjacks Building & Construction 3 05-05-2009 06:17 PM
Joist, rafter, and stud spacing for shed? Badfish740 Building & Construction 2 10-27-2008 04:12 PM
rafter spacing Clutchcargo Building & Construction 5 08-11-2007 02:14 PM
