Rafter Size - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-09-2010, 11:40 AM   #1
rafter size
I'm planning to do a stick built roof on a room span of 38 feet, so the run is actually down to 19 feet. Will have a 5/12 pitch. There will be an interior wall perpendicular to the rafters and a couple walls parralell breaking up the length of the room. Would a 2x8 rafter satisfy this span? This will be built in Virginia.
Kealii is offline   Reply With Quote
Old 07-09-2010, 12:37 PM   #2
Depending upon the species of wood, grade etc a 2x8 will span around 16' w/16" OC
A 2x10 would be a better choice
Not sure on the snow load where you are
I went with 2x12's for a similar span here
Are you using fiberglass insulation or spray foam ?
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Kealii (07-09-2010)
Old 07-09-2010, 08:31 PM   #3
Thank you for the info. The live load is 10psf. Also, to further clarify, this is also an attic space so the insulation won't be in the rafters, but as an fyi it will be R38.
Old 07-09-2010, 09:09 PM   #4
General Contractor
Span Calculator
FYI, the American Wood Council ( http://www.awc.org/ ) has a span calculator on their website.
You play around with different spacing, loads and species: http://www.awc.org/calculators/span/...rcalcstyle.asp
Rory
RDG Read Development LLC
Portland, OR
Rory Read is offline   Reply With Quote
The Following User Says Thank You to Rory Read For This Useful Post:
Kealii (07-09-2010)
Old 07-11-2010, 06:58 PM   #5
Registered User
Rewards Points: 4,888
"Thank you for the info. The live load is 10psf. Also, to further clarify, this is also an attic space so the insulation won't be in the rafters, but as an fyi it will be R38." ------ 10 psf---- on what, exactly? R-38 ---- in the ceiling joists? And a bearing wall carrying the centers, or off to one side? Type of roofing material? Need more info........
Be safe, Gary
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Rafter Ties on Vaulted Ceiling timsgills Building & Construction 2 01-07-2010 04:02 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
duct work size justmefixin HVAC 2 09-20-2008 07:59 PM
