Rafter Construction - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-22-2006, 11:02 PM   #1
rafter construction
i want to build a roof over a 26' wide X 20' long barn on a 6/12.so i figure my rafters will be around 29' from ridge to tail. is it acceptable to scab 2x4x12,s together to obtain the length rafters i need?i also plan to place the rafters on 4'oc and deck it with metal attached to the rafters on 1x4 girts @ 2'oc.
I live in the new orleans area i dont have to worry about snow just hurricanes lol
Last edited by therigwelder; 06-22-2006 at 11:07 PM. Reason: wrong forum need carpentry
therigwelder is offline   Reply With Quote
Old 06-22-2006, 11:39 PM   #2
renovations
You're trying to span 26' with a 2x4? Is there already an existing roof that you're going to sit the new one on? What type(shape) is the roof? Shed (one slope), Gable (two slopes). The short answer is no, I wouldn't even walk on such a roof to build it. Perhaps I'm misunderstanding, can you clarify?
Bonus is offline   Reply With Quote
Old 06-23-2006, 06:13 AM   #3
General Contractor
joasis's Avatar
I think you need to recalculate your rafter run. Off the top of my head, I see a 15 foot or so run, depending on tails, why would you scab?
You say you want 4 feet OC? You probably need to think about engineered trusses, and using 2x's placed between the top chords on 3 ft centers. Sure you don't have a snow load, but there is wind pressure, uplift, coastal wind zone...a lot of things to think about.
joasis is offline   Reply With Quote
Old 06-23-2006, 06:23 AM   #4
Commercial Roofing
AaronB's Avatar
I think this is a joke.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 01:47 PM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 07:36 PM
Rafter Construction janetng Building & Construction 2 07-13-2006 06:58 AM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 03:57 PM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 11:19 AM
