Radiant Barrier ??? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-11-2011, 01:33 AM   #1
Radiant Barrier ???
Has anyone installed a radiant barrier under their roof? Are you happy with it? Was it worth it? Are you saving any money? Does your cell phone still work?
Living in Florida and I'm thinking to give it a try, but wanted input from those whov'e tried it already.
Dogfish is offline   Reply With Quote
Old 11-11-2011, 02:29 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Living in a warm climate as you do, a radiant barrier might do some good if the conditions of the install are correct.
No insulation directly on the barrier, you need to have the air gap.
There is no sheathing on it now and you are planning on installing sheathing anyway.
Plus other factors.
Andy.
AndyGump is offline   Reply With Quote
Old 11-11-2011, 07:23 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
Needs an air space to work properly and radiant barriers and no replacement for proper insulation layers.
Old 11-11-2011, 05:11 PM   #4
Registered User
Rewards Points: 4,902
This covers most of the key points: http://www.greenbuildingadvisor.com/...search-problem
That said, for your location: http://www.fsec.ucf.edu/en/publicati...N-15/index.htm
Gary
Installing radiant barrier in attic sheslostcontrol Insulation 12 11-23-2011 03:20 PM
Radiant Barrier vs. eShield rtc1 HVAC 2 04-08-2010 10:56 PM
Radiant Barrier + Insulation with Metal Roof customfab Building & Construction 8 02-16-2010 10:47 PM
Radiant barrier with faced insulation? luci468 Building & Construction 1 07-18-2009 04:49 PM
