Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-10-2011, 11:16 AM   #16
MJW
Questions on proper roofing installation
Originally Posted by seeyou View Post
That flashing looks like ass.
I was gonna say something worse. I see a lot of this locally. Good shingler - bad flasher.
I agree. Although I don't see anything that would really be considered absolutely wrong. My opinion or someone else's may differ, but it would still pass code.
I'm not sure on this situation, but usually this is where the cheaper bid maybe got the job.
MJW is offline   Reply With Quote
Old 04-12-2011, 02:54 AM   #17
Called roofer last night and he offered to silicone the nailheads and the 3/4" gap in the step flashings
Manufacturer docs say to use ASTM.... Roofing cement on railheads. But since roof and flashings are brown he says brown silicone is the way to go.
I'm thinking the asphalt based cement will bond better.
Thoughts?
I also read somewhere about pressing some excess roof granules into the cement. To match the roof color. Thoughts on that?
bikepilot is offline   Reply With Quote
Old 04-12-2011, 03:11 AM   #18
Doing This Way Too Long
At this point it's all about aesthetics and with your low pitch no one except you is going to know it's there. Silicone and asphalt don't mix well yet I see a lot of roofers use GeoCel and the like on asphalt roofs which they shouldn't do. It is best to use an asphalt or urethane based mastic to cover the nailheads.
OldNBroken is offline   Reply With Quote
Old 04-12-2011, 03:18 AM   #19
I guess I'll have them use asphalt on the shingles and silicone on the flashings?
Old 04-12-2011, 07:51 AM   #20
Shut in w/o Home
seeyou's Avatar
Geocell 2300 (Purple tube) is not silicone based (it's a tripolymer - whatever that is) and is very compatible with asphalt based roofing products. The only roofing limitations listed are polystyrene and acrylic glazing. But I agree that silicone caulks have no place on roofs.
seeyou is offline   Reply With Quote
Old 04-12-2011, 09:59 AM   #21
Personally I prefer NP1 for our caulking needs but there are many good products out there.
Old 04-12-2011, 10:08 AM   #22
Shut in w/o Home
seeyou's Avatar
I'd never use NP1. A snow load will cause it to collapse.........
Just kidding for anyone else reading.........
The Following User Says Thank You to seeyou For This Useful Post:
Roofmaster417 (04-12-2011)
Old 04-12-2011, 10:25 AM   #23
Tags
certainteed, code, roofing
Proper Roofing Techniques? JoWarren Roofing 5 03-26-2011 04:26 PM
Gutter installation along drip edge questions: Nor-Cal Owner Roofing 4 02-02-2011 10:26 PM
Window Installation Questions cumak Building & Construction 0 05-05-2010 01:22 PM
New Construction window installation questions gone_fishing Remodeling 10 04-24-2010 09:09 PM
Many ROOFING Questions jelisak Roofing 7 02-16-2006 08:57 AM
