Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-17-2012, 02:21 PM   #1
Question for step flashing
Well I am gonna help someone with a roof and I have run some before but I am no pro. Where the main house meets the garage there is a overhang that goes back about 16" and is covered on both sides. So I worked on a job almost 2 years ago that was kinda like that and the guy I was working with didn't use flashing.
So should I use flashing under the overhang?
Btw the sooner I know the better, thanks !
Edit: and the overhang is only about 1' high
donaramu is offline   Reply With Quote
Old 09-17-2012, 05:15 PM   #2
chb70's Avatar
Yes, you should still use step flashing in that area also.
Can You Dig It!
chb70 is offline   Reply With Quote
skylight self stick flashing advice Earl0101 Roofing 2 04-30-2011 10:55 AM
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing 6 03-10-2011 04:19 PM
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 11:27 AM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 11:27 AM
proper steps in wrapping tyvek and flashing windows?? 4just1don Building & Construction 4 11-17-2008 07:10 PM
