Question About This Wind-damaged Flashing: - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-13-2012, 05:20 PM   #1
Question about this wind-damaged flashing:
Hey Folks,
I heard some rattling around on the roof after a good windstorm and went up to inspect. Looks like quite a bit of this flashing (about 3" wide) pulled away in several places. I'm not a roofing expert, and I noticed that it doesn't overlap with any shingles or the ridge cap, so for the life of me I can't figure out what purpose it serves... Does this need to get repaired/replaced? Is it a priority?
Many Thanks!
kazyctn is offline   Reply With Quote
Old 01-13-2012, 05:41 PM   #2
RFN-4A-LVN
Roofmaster417's Avatar
It looks like zinc strips to me.Rather than remove all of it I would use some tin snips and cut them off from where the pulled away.
Seal the nail holes and be done with it.If you try to remove all of it you could get into trouble in the valley if your not careful.
Roofmaster417 is offline   Reply With Quote
Old 01-13-2012, 05:48 PM   #3
RFN-4A-LVN
The zinc strip is for algae and lichen control.
Old 01-13-2012, 08:21 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Rm is correct. Zinc strips. Just cut it off where it's loose.
tinner666 is offline   Reply With Quote
Old 01-13-2012, 08:37 PM   #5
Thanks Roofmaster - That sounds about right. Should be an easy fix if it doesn't snow this weekend!
Tags
flashing , ridge cap , roofing
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 12:53 PM
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 11:27 AM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 11:00 PM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 11:27 AM
Flashing Question swr2000 Building & Construction 4 08-17-2008 10:00 PM
