Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-17-2008, 05:01 PM   #1
Question
question about replacing a shingle roof w tin
I have an older home that i am planning on replacing the existing ashfalt shingles w a double M tin roof.
The roof is a 2 / 12 pitch. The question i have is can i just go over the ashfault shingles or do i have to strip the roof,
put ice and water shield and 15lb felt on the 1x boards.
And would there be any benifet from puting I&W shield and felt on the existing shingles if i dont have to strip the shingles off.
Any advice would be helpful
Moparman is offline   Reply With Quote
Old 05-18-2008, 10:21 PM   #2
Hello,
There should be no problem going over the shingled roof but you will need a slip sheet between the metal and the shingles. The granuals will scratch the paint on the back of the panels and they will rust from the inside out.
Personally I would rip the old roof off.
Keith
roofboy is offline   Reply With Quote
Old 05-21-2008, 05:03 PM   #3
Thanks for the input Roofboy, now for the slipsheet u are talking about .. 15lb felt roll the same thing u are talking about?
And would there be any benefit from putting a starter row of ice and water shield down on the shingle under the tin?
I would prefer to leave the shingles up there due to the time consumption of ripping it off.
Old 05-27-2008, 10:51 PM   #4
the roofing god's Avatar
Send a message via MSN to the roofing god
typicaslly red rosin paper is used as a slipsheet
"If it`s worth doing,It`s worth doing right!!"
the roofing god is offline   Reply With Quote
Old 06-01-2008, 01:45 AM   #5
Hello,
I have been out of town for the last 2 weeks so I could not respond. What TRG said is correct though.
Keith
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat roof venting question vendejp Roofing 8 07-17-2008 04:45 PM
Replacing Asphalt w/ Cedar Shingle pbehnke Roofing 1 05-06-2008 02:28 PM
