Question About An Old Brick Chimney - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-27-2011, 10:22 AM   #1
Rewards Points: 319
question about an old brick chimney
Hi Guys, the roofer who fixed the leak around my chimney flashing said he would wash and paint my black, sooty chimney. I hesitated because (1) I wasn't sure if black soot would run down and streak my steep roof and (2) wasn't sure if pressure washing would loosen up the mortar between the bricks and create leaks and (3) it seems like painting a chimney would be like painting the exhaust pipe of a semi (just get dirty again real quick). I really don't know if my concerns are well founded or not and thought maybe someone could help me decide.
I just remembered that he said paint would act as a sealer. Thank you, Jean
DIherself is online now   Reply With Quote
Old 04-28-2011, 12:16 AM   #2
RFN-4A-LVN
Roofmaster417's Avatar
If you power wash anything with the wrong tip it could do some damage.I have never power washed a chimney but if correct accessories and pressure are honored then I see nothing wrong with it.A certain distance would have to be maintained.
A sealer specifically for chimneys/brick is available.As far as painting it could work IF the proper steps were taken to prevent chipping or flaking.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
DIherself (04-28-2011)
TV Mount onto Brick Fireplace- Brick Integrity? andrew.volkart Building & Construction 4 03-01-2011 08:21 PM
Drywalling over Brick Chimney and Lath Wall psubaron Building & Construction 0 02-17-2011 09:37 AM
Insulation behind brick chimney? scoutn General DIY Discussions 13 11-15-2010 06:39 PM
chimney pipe question naehring2000 HVAC 2 03-24-2010 07:29 AM
brick chimney that needs some help! gemelli2 Building & Construction 1 10-03-2007 01:41 PM
