Question About My Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-29-2009, 11:15 PM   #1
Question about my roof
Hello, I live in Oklahoma and had my roof installed in June of this year. After this installation, I noticed what I would call buckling (several shingles mildly elevated running in a vertical line) but at only one spot on the roof. I noticed about 6 more of these spots today (9/29/09) when I came home from work. To be fair, I can't see these spots unless I look at the roof with the sun at the proper angle in the evening. When I look up the roof at an angle (so that I can see the bottom edge of the shingles) I can't detect anything or see the "buckling". I have read that the tolerance is 1/8 of an inch for every 8 feet or something similar, but do not have an 8 foot straight edge to test this. The roof has no other problems and does not leak. I am going to contact the installer tomorrow and believe that the one ridge that has been present since the install is due to improper spacing between the decking (have looked in the attic and there is no gap between the boards at that location). I just wanted to check with prople who know more about this than I do. Thanks.
megma42 is offline   Reply With Quote
Old 09-30-2009, 02:39 AM   #2
Plywood must have space in between sheets.I tell my guys to leave the width of a nail(spike)in between sheets.Failure to do so would cause buckling.
johnk is offline   Reply With Quote
Old 09-30-2009, 03:31 AM   #3
Commercial Roofing
AaronB's Avatar
This thread is useless without pictures.
Anything anyone tells you would be speculation nad guesstimating.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-30-2009, 07:28 PM   #4
Here are pictures of my problem, thanks.
Old 09-30-2009, 10:02 PM   #5
Commercial Roofing
AaronB's Avatar
Looks like a decking issue to me from where I sit.
Old 09-30-2009, 10:10 PM   #6
Thanks, that is what I thought also. I have yet to get the installer out, but was wondering if a problem like this leads to leaks or could lead to leaks. I appreciate your help.
Old 09-30-2009, 11:10 PM   #7
Commercial Roofing
AaronB's Avatar
It absolutely could. Get it fixed stat.
Old 09-30-2009, 11:29 PM   #8
Thank you very much, good to know.
Hip Roof Ventilation Question tecboy Roofing/Siding 7 06-17-2008 10:37 AM
question about replacing a shingle roof w tin Moparman Roofing/Siding 4 06-01-2008 01:45 AM
Sagging roof - framing question G.P. Carpentry 7 12-26-2005 05:32 AM
Question about roof wndsrfgrl Roofing/Siding 15 12-09-2005 05:35 PM
Torch Roof Replacement Question Chad262 Roofing/Siding 6 09-21-2005 08:29 AM
