Question About Lag Screws Into Roof RE Satellite - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-05-2009, 11:51 AM   #1
Rewards Points: 270
Question about lag screws into roof RE Satellite
I am removing a satellite dish from the previous owner's service, and re-utilizing the satellite dish mount, for my directional GMRS (465mhz UHF radio) antenna. I am removing it, and moving it from 1 side of the house to another. So the questions are :
1) What do I put into my asphalt shingle roof to make sure I do not get leaks where I removed the old lag screws
2) How do I know where is "OK" to screw 2.5" lags into the roof? Do I look at where they put the roofing nails?
Thanks a lot.
pcampbell is offline   Reply With Quote
Old 01-05-2009, 11:57 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Go down the page to items #20 and #21. It's the only right way to do it.
http://www.sadoun.com/Sat/Order/Dish...ish-mounts.htm
tinner666 is offline   Reply With Quote
Old 01-05-2009, 12:15 PM   #3
Rewards Points: 270
I see.... what I have is the standard mount, which is like #10 or #11. And they had just gone right through the shingles. I guess that isn't good?
If putting it on the roof is the wrong thing to do, I can just as easily put the mount on the side of the house. However I will still need to fill the holes that the lag screws made from removing it from the roof, from the previous install.
Old 01-05-2009, 03:50 PM   #4
Rewards Points: 270
Anyone... about filling the holes in the roof made from the lag screws???
Old 01-05-2009, 04:53 PM   #5
Electrician
I would replace the shingles myself.
chris75 is offline   Reply With Quote
Old 01-05-2009, 07:02 PM   #6
Norge Supply
Thumbs up
Answer
We sell a product called Geocel 2300 it comes in a culk tube or brush grade. It is a clear adhesive that you will not even notice it on the roof.
Roofing Applications
Chimney Caps
Gutters
Leak Repair
Parapet Caps
Roof Projections
Roof Seams
Screw Heads
Skylight Frames
Termination Points
Valleys
Norge Building Suuply is offline   Reply With Quote
Old 01-06-2009, 12:16 AM   #7
Tom Struble's Avatar
Rewards Points: 2,002
best to just replace the shingles
Tom Struble is offline   Reply With Quote
Old 01-06-2009, 07:28 AM   #8
the roofing god's Avatar
Send a message via MSN to the roofing god
A Short term repair would be to put pieces of metal under the tabs where the holes are,a touch or two of elastomer to the bottom of the metal pieces would hold them in place
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 03-11-2009, 10:23 AM   #9
Pole mounts on the ground are the way to go in my opinion.
Or just use a satellite tripod. Cheaper and easier. Also Aeon has better prices than Sadoun.
DigitalDodge is offline   Reply With Quote
Old 03-11-2009, 11:23 AM   #10
Doing This Way Too Long
Rewards Points: 532
"We sell a product called Geocel 2300 it comes in a culk tube or brush grade. It is a clear adhesive that you will not even notice it on the roof."
Norge, little FYI on that product. First off, geocel puts out a very good product and I use it a lot but there are two things:
1. Geocel is not very compatible with asphalt, nor does it generally adhere well with shingles.
2. You will notice the clear geocel because after less than a year it begins to yellow and this shows up on most colors of shingles out there.
Geocel has many fine uses, but patching asphalt shingles is not one of them.
In the end replacing the damaged shingles is the proper way to go, but TRG also gave you a very good temporary/permanent fix.
Roof-mounted dishes are one of my pet peeves. Many lazy dish installers do it because it's the easiest way for them. If I have any control over it on any job, I require they mount it on the facia or wall of the bldg. Lazy roofers will also just pump caulk into the holes of those shingles and call it a day.
OldNBroken is offline   Reply With Quote
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 01:19 AM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 06:37 PM
Hip Roof Ventilation Question tecboy Roofing/Siding 7 06-17-2008 10:37 AM
question about replacing a shingle roof w tin Moparman Roofing/Siding 4 06-01-2008 01:45 AM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
