-   -   Question about lag screws into roof RE Satellite (http://www.diychatroom.com/f9/question-about-lag-screws-into-roof-re-satellite-35146/)
pcampbell 01-05-2009 10:51 AM
I am removing a satellite dish from the previous owner's service, and re-utilizing the satellite dish mount, for my directional GMRS (465mhz UHF radio) antenna. I am removing it, and moving it from 1 side of the house to another. So the questions are :
1) What do I put into my asphalt shingle roof to make sure I do not get leaks where I removed the old lag screws
2) How do I know where is "OK" to screw 2.5" lags into the roof? Do I look at where they put the roofing nails?
Thanks a lot.
tinner666 01-05-2009 10:57 AM
Go down the page to items #20 and #21. It's the only right way to do it.
http://www.sadoun.com/Sat/Order/Dish...ish-mounts.htm
pcampbell 01-05-2009 11:15 AM
I see.... what I have is the standard mount, which is like #10 or #11. And they had just gone right through the shingles. I guess that isn't good?
If putting it on the roof is the wrong thing to do, I can just as easily put the mount on the side of the house. However I will still need to fill the holes that the lag screws made from removing it from the roof, from the previous install.
pcampbell 01-05-2009 02:50 PM
Anyone... about filling the holes in the roof made from the lag screws???
chris75 01-05-2009 03:53 PM
I would replace the shingles myself.
Norge Building Suuply 01-05-2009 06:02 PM
Answer
We sell a product called Geocel 2300 it comes in a culk tube or brush grade. It is a clear adhesive that you will not even notice it on the roof.
http://www.geocelusa.com/core/prdb/p...ll_image_8.jpg
Roofing Applications
Chimney Caps
Gutters
Leak Repair
Parapet Caps
Roof Projections
Roof Seams :thumbup:
Screw Heads
Skylight Frames
Termination Points
Valleys
Tom Struble 01-05-2009 11:16 PM
best to just replace the shingles:thumbsup:
the roofing god 01-06-2009 06:28 AM
A Short term repair would be to put pieces of metal under the tabs where the holes are,a touch or two of elastomer to the bottom of the metal pieces would hold them in place
DigitalDodge 03-11-2009 09:23 AM
Pole mounts on the ground are the way to go in my opinion.
Or just use a satellite tripod. Cheaper and easier. Also Aeon has better prices than Sadoun.
OldNBroken 03-11-2009 10:23 AM
"We sell a product called Geocel 2300 it comes in a culk tube or brush grade. It is a clear adhesive that you will not even notice it on the roof."
Norge, little FYI on that product. First off, geocel puts out a very good product and I use it a lot but there are two things:
1. Geocel is not very compatible with asphalt, nor does it generally adhere well with shingles.
2. You will notice the clear geocel because after less than a year it begins to yellow and this shows up on most colors of shingles out there.
Geocel has many fine uses, but patching asphalt shingles is not one of them.
In the end replacing the damaged shingles is the proper way to go, but TRG also gave you a very good temporary/permanent fix.
Roof-mounted dishes are one of my pet peeves. Many lazy dish installers do it because it's the easiest way for them. If I have any control over it on any job, I require they mount it on the facia or wall of the bldg. Lazy roofers will also just pump caulk into the holes of those shingles and call it a day.
