Question About Carlisle Ice And Water Dam - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-19-2007, 08:35 AM   #1
FatAugie's Avatar
Question
Question about Carlisle Ice and Water Dam
Anyone ever use this stuff?
There's a guy who has a roll and a half he wants to get rid of for $50, and I was thinking of using it for the rake edges of the roof. I already have GAF Weather Stopper for the eaves. Since the rake edge is a "nice, but not necessary" situation, I thought I could save a few $$$ using this instead of buying a new roll or two of GAF's.
Any thoughts?
FatAugie is offline   Reply With Quote
Old 08-19-2007, 05:57 PM   #2
Rewards Points: 5,336
Looks like a similiar product. How many sq feet in a roll and a half?
Ron
Old 08-19-2007, 07:08 PM   #3
FatAugie's Avatar
I see two different length's on the spec sheet....it could be a 33' roll or a 66' roll. I have a question into the guy. If the whole roll is a 1 sq roll, and he has part of a second...in other words less than two square, then it would be cheaper to buy the GAF at Home Depot ($49 for a 2 square roll)
Old 08-19-2007, 11:41 PM   #4
The roll the Jericho,NY Home Depot sells is 1 1/2 of a square for about $50.00. I can pick up the 2 square version at a local lumber yard for the same price. The details of the transaction will dictate the value of the deal.
Ron
Old 08-25-2007, 06:32 PM   #5
Question
Question on Ice and Water
Looking for opinions on using ice and water around the bottom perimeter of walls under vinylsiding on a slab ranch without gutters. Thanks.
HomeImpCons is offline   Reply With Quote
Old 08-25-2007, 08:37 PM   #6
FatAugie's Avatar
Interesting application, but if I was you I'd start a new thread in a more appropriate forum, like the building and construction section. More people will see it.
Old 08-26-2007, 12:25 PM   #7
the roofing god's Avatar
Send a message via MSN to the roofing god
THE CARLISLE IS SIMILAR TO GRACE i BELIEVE,the ice +water is fine at the bottom of the siding but cover it w/tyvek so as to prevent oilcanning/staining from the petroleum product-you shouldn`t put felt/ice shield under vinyl w/out a protective barrier
the roofing god is offline   Reply With Quote
