Originally Posted by Mastershredder
.....he noticed that the plywood
on the roof looked a little damp and there was mold growing on the
wood. The insulation is blown in and whoever did this never installed
any kind of vapor barrier.
If the plywood is damp = You have a leak on your roof. If it has mold, then it has been leaking for some time now....
How old is the roof? Was the roof visually inspected by someone getting up there and walking around? The proper repair with this is to address the roof leak,
not a vapor barrier. See next point...
1) How hard would it be to install a vapor barrier? I know everything
has to be sucked out, then the barrier has to be installed, then new
insulation has to be blown in. This sounds pretty tricky since the
only access is the attic crawlspace and I don't believe the joists
would handle a lot of weight.
You do not want to install a vapor barrier up there, if there is one up there already. As stated by Darylh, you should already have one facing the warm area. If that is the case, then you DO NOT want to add another one...
See this link regarding attic insulation:
http://www.powerhousetv.com/stellent...577.hcsp#P-4_0
2) I don't believe I saw any soffits on the outside of the house.
Would adding soffits and making sure there was adequate airflow in the
attic correct the problem?
Does the roof have a ridge vent installed?
If you don't have soffits, then you must not have any overhanging eaves on your roof line.
By the sounds of it...it would be difficult to 'add' soffits without re-framing the roof line.....
If you do infact have a small eave/soffit, you can install small circular or rectabgular vents.
See the link below:
http://www.cornerhardware.com/howto/ht076.html
