Question About Adding A Shed Roof To A 12x12 Pitched Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-03-2012, 05:19 PM   #1
Question
Question about adding a shed roof to a 12x12 pitched roof
How far up a 12x12 pitched roof should you put a ledger board when adding a shed roof to cover an 8ft deck using 8' posts? Is there a typical slope when covering a deck?
ccrhoden is offline   Reply With Quote
Old 09-03-2012, 10:55 PM   #2
way too vague, as to the pitch it could be anything you want it to be I will say that 12 pitch will never catch a 12 pitch roof, try a 4 pitch. If you cant set it up using math, return to dumb math-nail a 2X4 to the 8' post to get your soffit distance, nail a board to the existing house fascia to represent the rise you want to establish, get a string and line it up, now you will know where to nail the "ledger" board. To cut the angle and birdsmouth, now you an lay the board on your ledger to span where you want to go and just mark what you want to cut off.
Rob Michael
Robert J. Michael Homes, Inc./RJM Build
rjmbuild.net
RJM Build is offline   Reply With Quote
installing a metal roof on a shed will02 Roofing/Siding 15 04-08-2014 03:41 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 10:00 PM
Roof Rafter question Rookie3550 Building & Construction 3 07-29-2010 02:30 PM
Tie a shed roof into existing 6/12 roof jj1122_2000 Building & Construction 1 02-18-2009 10:37 PM
Adding a roof over a bulkhead? 1parkpointer Building & Construction 1 12-08-2008 10:24 AM
