Pvc Trim Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-22-2013, 04:10 PM   #1
pvc trim question
Hi,
When installing PVC trim like Azec at the top of vinyl siding directly under soffit do you use the Azec as a channel to hold the end of the soffit or do you run the azec under the J or F channel?
markharmon is offline   Reply With Quote
Old 07-22-2013, 04:30 PM   #2
Rewards Points: 13,300
If you leave it slightly lower then the width of the soffit you can use the rim to hold it up for a better look.
Still going to have to use upside down J on the bottom side.
I also insert strips of utility trim (also called under sill trim) up inside the upside down J.
That way I can use a Snap Lock tool to punch rectangular holes with tabs in the top of the siding. When the sidings pushed up in place it's impossible to remove without a Zipper tool. It can also still expand and contract so it's not going to buckle up.
Most siding guys just use silicone or nails in the weep holes at the bottom, one reason why I see it falling off all the time.
Old 07-22-2013, 05:51 PM   #3
The space between the bottom of the azec and the j channel for the siding isn't that a potential spot for water or can that area be caulked?
Old 07-22-2013, 06:16 PM   #4
Got a picture?
Is there not an over hang on the roof?
A proper siding job should not need any caulking. Some people do just for looks but why add another mantaince issue?
Old 07-22-2013, 06:20 PM   #5
Got a picture?
Yes there is an overhang but driving rain can get anywhere.
Old 07-22-2013, 06:23 PM   #6
If the siding job was done right there should be house wrap all the way up to the area where the soffits are.
Unless you turn the building up side down water should have no effect up that high.
Old 07-22-2013, 06:50 PM   #7
Do you recommend putting wrap on the sub fascia boards?
Question: 3/4 Scotia trim on stairway skirt. Glue, nail, both? pjw73nh Carpentry 25 08-17-2012 12:27 PM
Question or two about redoing trim and walls asbury park Painting 19 01-17-2012 09:24 PM
Deadbolt and Wood Trim question troymcclure Building & Construction 8 05-18-2009 07:12 PM
door trim question pjm Carpentry 3 06-27-2008 07:32 PM
interior wood trim, surface preparation question copacetic Painting 3 04-25-2008 08:52 PM
