Pvc Pipe Gutters How To Secure?? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-11-2014, 08:33 PM   #1
Rewards Points: 145
pvc pipe gutters how to secure??
I wanted to use pvc pipe split in half length wise as gutters on my over hang. But how can I secure the piping?
wantboost is offline   Reply With Quote
Old 08-11-2014, 09:02 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,234
Get some gutter half round brackets.
How are you planning to split the PVC?
Old 08-11-2014, 09:03 PM   #3
Rewards Points: 145
I was thinking table saw or get hardware store to cut it??
Old 08-11-2014, 09:09 PM   #4
Rewards Points: 145
I just found these products http://www.rona.ca/webapp/wcs/stores...rds=pvc+gutter
Old 08-12-2014, 06:06 AM   #5
Rewards Points: 13,960
My first question is why?
Way more work then it's worth.
What's wrong with seamless gutters?
Old 08-12-2014, 06:25 AM   #6
Just trying to clean up the statically charged chips after cutting will be a challenge.
How do you plan on adding down spouts?
No store I've ever heard of is going to be cutting these for you.
Cutting PVC is going to dull and gum up that blade.
Even 4" PVC would make for a narrow gutter.
Windows on Wash (08-12-2014)
Old 08-12-2014, 07:27 AM   #7
While the plastic gutters are nice for DIY type applications, seamless will work much better and shouldn't be much more.
Call a good gutter company and have them do it. There are certain projects, gutters being a great example, where it is better to just pay someone to do it that does it everyday.
Old 08-12-2014, 10:49 AM   #8
Neat idea...I have actually thought of this but everyone is right. There are too many complications to deal with when you can just do seamless gutters.
Eskie is offline   Reply With Quote
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 05:50 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
