PVC Corner Trim - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-02-2013, 07:55 PM   #1
Rewards Points: 396
PVC corner trim
I am planning on vinyl siding a garage and was curious what your thought were on using an pvc outside corner piece instead of a vinyl siding outside post?
detroittigerfan is offline   Reply With Quote
Old 10-02-2013, 08:21 PM   #2
Rewards Points: 12,824
Far more expensive to do it that way.
Only way I would do it would be to buy one made just for that, not make one up.
It's made in one piece and has a dado to fit the siding.
Old 10-02-2013, 08:27 PM   #3
Framing Contractor
Rewards Points: 96
I would probably opt for a wider vinyl corner in white (if that is your trim color) If only the corners are PVC, you wont get much wow for your dollars.
sixeightten is offline   Reply With Quote
Old 10-02-2013, 08:42 PM   #4
Rewards Points: 396
The reason im asking is because the rake side of the garage has pretty much no overhang and if I use a vinyl outside piece it doesn't have anything to cover the top of it. Any suggestions?
Old 10-02-2013, 09:00 PM   #5
If there's house wrap around the outside corner it's not going to matter.
What little bit of water will just get in will just run to the bottom.
If you were thinking of using 1 X vinyl lumber for an outside corner it's only 3/4" thick. The J molding will be 5/8's so it will stick out past it and water will get in behind it.
Old 10-02-2013, 10:25 PM   #6
Rewards Points: 396
Is there a way to cap off the top of the outside vinyl corner post?
Vinyl corner guard for bathroom window? CubsWin Windows and Doors 9 05-22-2012 08:40 AM
Paper Faced Metal Corner Bead & Multiple Intersecting Corners Fire4Effect Drywall & Plaster 2 04-09-2012 10:53 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
