Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-06-2008, 07:30 PM   #1
putting a roof on a trailer
Hi everybody! Doing a trailer roof, the trailer has a transitial bump for different heights that already exist. Going to need some overlays for a pitched roof (instead of almost flat as it exists). Forgive me if this sounds silly but is there any other method I could use than what I've done before...the bottom plate is 2 x 4 but I end up stacking and nailing them together one on top of each other to reach the height I need for starting the overlays. I don't think I can do it any other way but doesn't hurt to ask.
Some roofs, depending on each one, can go as high a 5 plates stacked..jeeze. Thanks in advance for any advice
Maryruth4 is offline   Reply With Quote
Old 03-06-2008, 07:33 PM   #2
Super Moderator
Can you post any photos of what your roof looks like now?
If not, do you have a link to the manufacturers site with a preview of the mobil trailer that you are speaking of?
Ed
Ed the Roofer is offline   Reply With Quote
Old 03-06-2008, 07:39 PM   #3
Thanks for the reply Ed. No I don't have any photos...I just looked at it today. I believe it is prob late 70's and no clue of manufacturer. It is 12 x 58 with your basic 1 x 3 construction..has an aluminum roof now.
Old 03-06-2008, 10:53 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
The last time I saw a older trailer that was retroed with a Peak Roof, and new siding, they used 2x2's on the side to allow new insulation, and Vinyl Siding to be installed, and tied in the Roof Trusses. If I recall, then attached runners down the length of the roof tied to the members under the Alumin skin, then attached the Trusses, which where made by a local Truss company by spec.
Over all, the R factor was raised, along with new doors and windows helping.
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
Putting a new metal roof on got i got questions aokss Roofing 9 06-10-2006 01:06 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing 1 01-02-2006 07:01 PM
