-   -   putting a roof on a trailer (http://www.diychatroom.com/f9/putting-roof-trailer-18112/)
Maryruth4 03-06-2008 06:30 PM
Hi everybody! Doing a trailer roof, the trailer has a transitial bump for different heights that already exist. Going to need some overlays for a pitched roof (instead of almost flat as it exists). Forgive me if this sounds silly but is there any other method I could use than what I've done before...the bottom plate is 2 x 4 but I end up stacking and nailing them together one on top of each other to reach the height I need for starting the overlays. I don't think I can do it any other way but doesn't hurt to ask.
Some roofs, depending on each one, can go as high a 5 plates stacked..jeeze. Thanks in advance for any advice
Ed the Roofer 03-06-2008 06:33 PM
Can you post any photos of what your roof looks like now?
If not, do you have a link to the manufacturers site with a preview of the mobil trailer that you are speaking of?
Ed
Maryruth4 03-06-2008 06:39 PM
Thanks for the reply Ed. No I don't have any photos...I just looked at it today. I believe it is prob late 70's and no clue of manufacturer. It is 12 x 58 with your basic 1 x 3 construction..has an aluminum roof now.
gregzoll 03-06-2008 09:53 PM
The last time I saw a older trailer that was retroed with a Peak Roof, and new siding, they used 2x2's on the side to allow new insulation, and Vinyl Siding to be installed, and tied in the Roof Trusses. If I recall, then attached runners down the length of the roof tied to the members under the Alumin skin, then attached the Trusses, which where made by a local Truss company by spec.
Over all, the R factor was raised, along with new doors and windows helping.
