-   -   Putting a base on the roof for my AC condenser (http://www.diychatroom.com/f9/putting-base-roof-my-ac-condenser-118208/)
garya505 09-24-2011 04:06 PM
1 Attachment(s)
I'm putting a base on the roof for my AC condenser, sometimes call a "roof jack". See attached photo. It will have a solid top and 18-gauge metal cap, and will be totally sealed. I was just wondering if I should foam the inside of it. There's nothing inside it, and no penetration in the roof. Any thoughts?
fabrk8r 09-24-2011 04:47 PM
We make the entire unit of metal and call it a "roof curb". We do line the interior with 1" fiberglass duct liner when we make them from metal to keep condensation from becoming a problem.
Even though the wood probably won't sweat I would put fiberglass batting in yours and make sure the metal cap is well insulated. I would glue the insulation to the metal cap just to be sure there are no air pockets. The last thing you want is condensation building up inside the curb and causing structural damage, especially if it gets below freezing where you are.
fabrk8r 09-24-2011 05:21 PM
I looked closer at your "roof jack" and can't see any pitch. Is your roof flat or is it just me?
garya505 09-24-2011 11:49 PM
You're right, there's no pitch in the jack itself. The roof is nearly flat. I haven't actually measured the slope, but it's probably only about 1/8 inch per foot. This type of roof is common around here. We don't get a lot of rain.
BTW, I am putting an extra rubber pad under the anti-vibration pads on one side of the condenser, adding 3/8" to that side to level the condenser, if it really matters (it probably doesn't).
garya505 09-25-2011 04:27 PM
The top is 7/8 wood (2 sheets of 7/16 sheathing). The metal cap is 18 gauge galvanized. I think I'll just fill it up with some left-over fiberglass insulation I have. That should help with any noise that might get in there.
Oh, and I think the roof slope is closer to 1/4" per foot, not 1/8" like I said earlier.
garya505 09-29-2011 11:26 AM
1 Attachment(s)
How's this look?
fabrk8r 10-01-2011 07:59 AM
Looks good Gary!
Are the corners of the cap welded to prevent water from wicking under the cap?
We usually bend a 1/2" drip edge on caps like that, but in your situation you'll be fine because of the overhang.
Windows on Wash 10-01-2011 10:05 AM
+1
Looks very well done.
garya505 10-02-2011 12:08 AM
Originally Posted by fabrk8r (Post 739415)
Looks good Gary!
My sheet metal guy didn't weld the corners, but the gap at the corner is tight and he put some kind of sealer inside the corner. If it was commercial I'd want the corners welded but it should be OK for what I need.
Horseygirl 10-02-2011 09:17 AM
Gary,
That looks fabulous!! Great job!!
After looking at this beautiful piece of work, I was thinking towards the future when/if the zinc coating starts to wear off subjecting the cap to rusting. You might want to consider priming and painting. You must treat it with a solvent to get the protective oily film left on from the mill off thus allowing paint to adhere to the surface. Being that the unit is minimally pitched, it would be subjected to elements such as standing water, snow, ice,condensation, that could reduce the life of the original coating. It's easier to put that extra insurance on now rather than later when everything is set up.
Just food for thought!!
garya505 10-02-2011 05:08 PM
Originally Posted by Horseygirl (Post 740160)
Gary,
Thanks for the tip. I had thought about that, but we don't get much rain around here and the humidity is very low most of the year. Galvanized sheet metal seems to hold up for a very long time outside. On swamp cooler ducts the metal will will rust after maybe 20 years or so, but that's another matter. ;)
