If I decide to go with a ridge vent (which is the direction I'm leaning), what are the pros and cons of rigid vs. roll-type ridge vents? I plan to install it myself, and would appreciate any tips and advice. Thanks in advance.
I think I read in one of the forums that someone suggested NOT using a ridge vent on roofs with less than 6-12 pitch because snow and rain get inside. Does anyone have experience with this?
I'm not a pro roofer, but I have a big one for you in the "tips & advice" category:
Before cutting your ventilation slot, get up in your attic and check the underside of your roof to see where the highest full sheet of OSB or plywood ends. If the original/last roofer did like mine, and ran a filler strip the last few inches up to the ridge, you will likely have problems and you'd better decide right now how you're going to handle that. If you want to support it, do it before you cut. If not, call roofers now. Besides my recent thread detailing what I encountered, there are a couple other threads dealing with similar experiences.
Also, if you haven't done so, check from underneath and see where your rafters are located relative to any hip-ridge intersections (if applicable). This may affect how far you want to extend your vents if you have a hip roof.
Most ridge vents can be installed on pitches 3/12 and greater.
Roll Vent is faster and easier to install but has a softer nailing surface requiring some "feel" during nailing" as it can be compressed if over nailed.
The 4' sectionals are more rigid but take longer to install and may be less attractive than the rolled products. Checkout www.benjaminobdyke.com. They are the inventors of the "rolled product" and also offer a selection of rigid sectional products. They vary in design and venting capability. They have a great customer service group to answer any questions.....
Thanks, Gary. I had been to a couple of those sites for the past couple of days and they are very helpful. I've gone through these forums, too, and have found LOTS of helpful information. I narrowed down my decision to a ridge vent over using mushroom vents at the top of the peak, and had decided on AIRVENT. But, when I spoke with someone at Lowe's, he said he preferred the owens corning rolled ridge vent because it's seamless. Honestly, I had not even considered a rolled ridge vent until he mentioned that. Now, I have another decision to make: rolled or not rolled!
Thanks, Geoff, that's just the type of information I was looking for. I still haven't started the project (fished this weekend, instead), and was still hoping for more opinions before deciding. Yours was very helpful. Thanks.
Many here are partial to Shinglevent II by airvent. Good chance your Lowe's "expert" only knows what he stocks. Main reasons for preferring shinglevent is better airflow and the rolled venting can get compressed, reducing their already lower airflow. I've also seen attics fill up with snow on lower slopes with a very dry, windblown snow storm.
Seams are irrelevant when installed properly and the mfr gives you all the instruction you need for installation.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
