Proper Way To Shim 2x4 Purlins - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-10-2011, 08:08 AM   #1
proper way to shim 2x4 purlins
I have a sagging gambrel roof. After pulling and reinforcing the structure much of the sag still remains.
I want to know the proper way to shim 2x4 purlins and put a metal roof on. The question is how much sag can be or should be shimmed to get the metal straight? Can furring strips or even 2x4 be used vertical (parallel) over the top edge of a rafter to shim out the purlins?
Can deck screws be used to attach the shim to the rafter and the purlin to the shim?
aphilstrider is offline   Reply With Quote
N00B needs to shim a hinge Leah Frances Carpentry 9 04-09-2011 09:17 AM
Load bearing shim ojee001 Building & Construction 4 12-07-2010 10:30 AM
standing seam over purlins hawaiidiy Roofing/Siding 5 11-21-2009 07:00 PM
Deck project - Shim beams or joists? jcims Carpentry 1 08-08-2009 08:02 PM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 03:56 PM
