Proper Vents To Soffits - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-14-2011, 07:20 PM   #1
Rewards Points: 346
Proper Vents to Soffits
Had someone in today to look at my roof, and he said the proper vents should extend all the way down to the soffit bay, that way they are guaranteed to get the airflow from the soffit. (This is in a cape, in the kneewall area, or crawlspace).
That just seems odd to me...how would warm air get out, if the only channel left to get out, is now all the way down in the soffit bays?
Appreciate any insight.
dougp23 is offline   Reply With Quote
Old 10-15-2011, 10:46 AM   #2
Rewards Points: 2,238
What's the size of the rafters (2 X 4, 2 X 6, 2 X 8, etc...)
How thick is the insulation?
Look into "baffles".
Got any soffit/roof vents?
rossfingal
rossfingal is offline   Reply With Quote
Old 10-15-2011, 03:01 PM   #3
Registered User
Rewards Points: 5,216
Depends on if there are any HVAC ducts there, which way to go- page #3: http://www.habitat.org/env/pdf/ceiling_and_attic.pdf
Air seal the attic, either way: http://www.finehomebuilding.com/PDF/Free/021105092.pdf
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
rossfingal (10-15-2011)
Old 10-17-2011, 07:47 PM   #4
Rewards Points: 346
The rafters are 2X6, the insulation looks to be R30, though there is no vapor barrier so hard to tell. It's jammed in pretty thick against the proper vents.
Roof has soffits and gable vents. Front is standard steep cape roof, back is pretty flat dormered cape.
No HVAC ducts up there!
I just thought if heat gets into the attic, it would rise, where it would be trapped since the only opening to get out would be via the proper vents, which would now be all the way down in the soffit bays....
ridge vents vs. box vents vs. turbine vents redaws Roofing/Siding 12 03-12-2012 10:48 PM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
Ridge vents? klab Roofing/Siding 7 06-28-2010 03:05 PM
Ridge vents and/or fan? mama2girls Roofing/Siding 20 05-27-2009 08:12 AM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 10:47 AM
