Proper Venting Of New Roof On Attached Garage - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-26-2009, 03:46 PM   #1
Proper venting of new roof on attached garage
Good day,
I have recently replaced a low slope (almost no slope) roof on my attached garage with a sloped roof. See attached "Microsoft Paint" doodle! The low slope was leaking badly and was suggested to replace it with a sloped one. Anyway, it is basically a sloped roof coming down from my home over top of my attached garage. I am wondering about the best method to insulate and vent. My own common sense tells me to create a sorta "attic" in the upper area of the new roof, and install those outside vents on either end of the newly created "attic" section. Also, run those rigid styrofoam venting channels down between the rafters to the soffits, insulating with the fiberglass overtop of the venting channels, and then vapor barrier. Does this sound like a reasonable solution, and if so, how often do I have to run the venting channels (ie: between every rafter, every second rafter, etc).
Am I going overboard here, or is this what should be done?
Any guidance would be appreciated!
Thanks,
- Joe
jlatulippe is offline   Reply With Quote
Old 11-26-2009, 04:24 PM   #2
Remodeling Specialist
Vent channels go in every rafter bay to prevent the insulation from touching the plywood any where that would be possible but not needed anywhere else. try to have an equal amount of air venting at the roofs bottom edge as at the top or ends. they do make a shed roof vent system so you could conceivably "ridge vent" at the top across the house wall.
Good luck
We do everything with quality and care
www.ronhoehn.com
Baron is offline   Reply With Quote
Garage Roof Suggestions NeedSuggestions Building & Construction 13 10-03-2009 09:29 PM
roof venting cathedral ceiling Pete H Roofing/Siding 16 09-29-2009 03:26 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
advice for insul./vent. of garage roof? King Dark Lake Roofing/Siding 3 04-15-2007 02:37 PM
